Fiat Punto 1.4 Blower Functioning Only in 4th Gear: Resistor & Wiring Repair Guide
Szelma1 11046 6
  • #1 16844244
    Szelma1
    Rate: 14
    Blows only in 4th gear. Quite often after damage to the resistor, I thought so, but the previous owner went all the way. The ankle is simply cut, two cables are twisted and the resistance is broken, 3 cables hang loosely.
    I want to do it as it should be, I bought a cube with a resistor, but I don't know which cables to connect with the cube. How to do it.
  • #2 16845050
    Pascalt
    Help: 9
    Rate: 143
    I do not know if it will be easier to drive around and take a look, or find cars on the Internet for parts and talk to the owner, or you can not look ...
  • #3 16845105
    Szelma1
    Rate: 14
    I found a diagram on the net, tomorrow I will be overwhelmed, maybe I will succeed.
  • #4 16849174
    migmig85
    Help: 85
    Rate: 337
    Buddy, but some reason for the burning of the resistor must be, most likely, the blower fan is worn so after replacement it can only be a good moment.
  • #5 16849253
    Szelma1
    Rate: 14
    The blower is already working perfectly, unfortunately I am not quite satisfied, because there is something wrong with the settings and directions of the airflow. Although it is set to max hot, warm air flies only on the first two settings, if I give it to the next, it starts to fly cold.
  • #6 16849261
    migmig85
    Help: 85
    Rate: 337
    How poorly it heats a stony heater ??
  • #7 16849267
    Szelma1
    Rate: 14
    Hot heater, you can't touch it, that's not it. The photo will express more than my translation.
The discussion revolves around a Fiat Punto 1.4 where the blower operates only in the 4th gear, likely due to damage to the resistor and improper wiring. The original poster has purchased a new resistor cube but is uncertain about the correct wiring connections. Responses suggest checking for underlying issues, such as a worn blower fan, which could cause resistor failure. The poster later confirms that the blower is functioning but experiences issues with airflow settings, where warm air only comes from the first two settings, and cold air is emitted at higher settings. A photo link is provided for further clarification of the issue.
