[Solved] Renault Clio 2: Wiper Failure - UCH-N2 vs Motor Issue, Immobilizer Programming, and Solutions
wrc126 9417 3
  • Wipers run continuously with switch disconnected, implicating UCH-N2
    #1 16293719
    wrc126
    The problem with the wipers after reading the posts and the forum and prubach, I'm waiting for someone to do it, because some people write that when you disconnect the cube from the switch and the wipers go, it's the fault of uch-n2 and the other that the motor may be broken, I checked with this cube from the driver on the steering wheel I drank
    it and the wipers go by themselves uch-n2 goes to buy but the immobilizer needs to be programmed and it's not that easy
    write back if you had such a case. When the ignition is turned on, they turn on and read where they want, they do not go so drive, so as the weather is on, I took the fuse out but this is not the solution
    Moderated By T5:
    3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and a brief description of the fault.
    3.1.13. Take care of linguistic correctness and follow the rules of netiquette. Do not post messages that make it difficult to deduce what their author wanted to convey.
  • #2 16295174
    thomas48
    Help: 44
    Rate: 83
    It might be better to check the mechanism first (gears at the engine), disassemble and see what it looks like inside (it costs almost nothing) and then if it is okay to replace other things.
  • #3 16305764
    wrc126
    I undressed and it turns out that it is a motor from kangoo No. 535 63102 someone wrote that it will not be that this is how the wipers work I do not know what the original number is, write whether this motor is also to work properly
  • #4 17359457
    wrc126
    Confused pins on the ankle problem solved
