Renault Kangoo 2007 1.6 16V - The immo indicator is on, the engine cannot be sta
MACIEK_M 14709 16
Why does the immobilizer light on a 2007 Renault Kangoo 1.6 16V sometimes stay on and prevent the engine from starting even though the starter turns?
Check the immobilizer reader/ring around the ignition switch and its wiring first; if that is sound, look at the ECU/UCH side and stored CLIP faults, because the H relay alone is unlikely to be the cause [#16314340][#16316611][#16357868] The initial suggestion was to replace the ECU power control relay (H relay / injection block relay), but after it was removed the fuel pump still worked and the immobilizer light went out, so that path does not match this fault well [#16311499][#16313467] Renault immobilizer faults can come from poor contact, damaged wiring, or interference in the code-reading path between the key reader and the engine ECU [#16357675][#16316611] One reply also pointed to a broken wire near the ignition switch and loop/reader area as a real-world cause of a similar fault [#16360341] CLIP may still show remembered or sporadic faults even when the car starts normally at the time of diagnosis, so checking stored history is important [#16314340][#16357868] If wiring and reader checks are fine, the engine ECU itself may have an internal problem reading or comparing the immobilizer code [#16357675]
  • #1 16311462
    MACIEK_M
    Help: 111
    Rate: 462
    Hello, from time to time, lately more and more often, after switching on the ignition the immo indicator does not go out and the engine cannot be started - the starter turns. After switching the ignition on several times, the indicator goes out and we can enjoy the ride.
    Where to look for the reason, because one day it won't fire at all.
    For advising everyone and everything - the indicator light is not flashing but is lit continuously and 1.6 16V is a gasoline engine.
    Everyone says the topic is familiar and typical for Renault, but probably not entirely.
    The topic has been going on for a year and it's time to solve it.
    Installation reviewed, clean and dry. Mass points' OK. EAR nice, dry, nothing suspicious.
    I am asking for specific advice.
    genek1000
    Help: 289
    Rate: 1057
    Replace the ECU power control relay.
  • #3 16311613
    MACIEK_M
    Help: 111
    Rate: 462
    Do you mean the H relay in the engine compartment - small - the designation in diagrams 238 - described as the injection block relay?
  • #4 16311683
    genek1000
    Help: 289
    Rate: 1057
    Yes . This one I mean. To check, simply pull it out and see if the LED is constantly lit. And the fuel pump will not talk.
  • #5 16311704
    MACIEK_M
    Help: 111
    Rate: 462
    OK, I'll check back tomorrow and let you know.
  • #6 16313467
    MACIEK_M
    Help: 111
    Rate: 462
    -> genek1000 Thank you very much for the advice. It is a pity that this is not it.
    I checked, after removing this relay, the fuel pump is working and the immo indicator goes out.
    So you have to look further.
    Maybe someone has already solved a similar problem?
  • #7 16314327
    genek1000
    Help: 289
    Rate: 1057
    Are we talking about the same relay J in this version of the box
    Or in this version of the mailbox Renault Kangoo 2007 1.6 16V - The immo indicator is on, the engine cannot be sta
  • #8 16314340
    Pawel wawa
    Help: 1262
    Rate: 4432
    First, try to make diagnostics, everything will be clear. Probably the reader for repair. If you touch it, there is a chance that you will not start the car without replacing or repairing it.
  • #9 16315610
    MACIEK_M
    Help: 111
    Rate: 462
    -> genek1000
    Yes, relay J, I have the second version of the box - the lower drawing.
    -> Pawel wawa
    I was twice, made CLIP, there are no errors, admittedly there was no fault at the time of diagnosis - it does not occur on demand, only when it wants, more often.
    What reader are you talking about - it's just a key and a coil around the ignition.
    I have two keys, I recognize them correctly. The immo indicator lights up continuously and does not flash as if the key was not recognized correctly. I suspect a communication error between the engine ECU and UCH, cables and connectors checked, clean, dry
    No exchange, just what?
    I have touched it for a long time and I have a little idea about it, I would like to fix it before it fires permanently.
    I am thinking about replacing the ECU and UCH, but I am not sure it will help.
  • #10 16316611
    Pawel wawa
    Help: 1262
    Rate: 4432
    MACIEK_M wrote:
    but I'm not sure it will help.
    Because it probably won't help if you take a good look, you have a ring on the ignition switch, there is also electronics inside. The ring is connected to this electronics, not to the UCH directly. No communication with the ECU, it is also flashing and not lighting the indicator. Anyway, see yourself by unplugging the plugs from the ECU and then from the ring.
    MACIEK_M wrote:
    I've been twice, made CLIP, no errors
    There may be inactive errors, a preview of the parameters at the time of the fault would say everything.
  • #11 16357675
    MACIEK_M
    Help: 111
    Rate: 462
    I rode for two weeks without a problem. Yesterday the problem returned again. I couldn't fire it for an hour, then it fired and it's good again.
    The problem with connecting under CLIP is that the fault appears suddenly and suddenly, without reason, disappears. It is hard to leave him in the workshop for two weeks - "maybe he will catch him at that time".
    Pawel Wawa wrote:
    No communication with the ECU, it also blinks and not lights up
    On one of the forums I found a description of how immo works at RENAULT - this is a fragment of Kangoo documentation available on the internet:
    That would mean that:
    1 / engine computer does not correctly recognize the code given from the immo - that is, a problem in the electrical system (poor contact, damaged wire, etc.), or any interference makes reading difficult.
    2 / engine computer has a problem reading the reference code from its memory for comparison with the immo code.
    I looked through the electrical installation quite carefully, I see no problem here. I also try to limit possible sources of interference - blower, LED daytime running lights, chargers, etc. and I don't see the difference.
    In the second case, it would only be necessary to replace the engine computer.
    It is puzzling that the fault appears and disappears, for no apparent reason, which would speak for a problem in the electrical installation, unless it is a hardware problem of the engine computer.
    I think I will bring CLIP with me. I wonder if DDT 2000 could read the errors from the immo and the engine cassette at the time of the fault?
    Well, unless someone else has an idea?
  • #12 16357868
    Pawel wawa
    Help: 1262
    Rate: 4432
    Clip should read the error even if the fault does not occur. It should be in remembered or sporadic errors. Only UNLESS after a dozen or so starts will disappear.
  • #13 16358021
    vemo
    Rate: 23
    Pawel wawa wrote:
    after a few starts it will disappear.
    lie
    Moderated By T5:
    3.1.2-3.1.3. Do not use multiple forum accounts. Such action causes confusion for users and incorrect presentation of statistics.
  • #14 16360210
    MACIEK_M
    Help: 111
    Rate: 462
    vemo wrote:
    lie
    is a very laconic answer, could you develop it somehow? Be more generous in the details, try to show that you are right, and not just offend others.
  • #15 16360341
    kamiloskop
    Help: 42
    Rate: 279
    If the fault remains in the fault history, it will not be erased even after the car has been fired 100 times. The last time I had a similar fault in the SC 1 lift, only that after the immo indicator was lit, the orange rectangle indicating the electronic fault was still fired. A loop near the ignition switch and exactly one cable was in some strange way broken off.
  • #16 16519605
    wojtek_abcd
    There was a similar problem in my Kangaroo, and I got rid of it by jumpering the plugs from the shock sensor. As he took his hand.
    best regards
  • #17 16519791
    MACIEK_M
    Help: 111
    Rate: 462
    The shock sensor has nothing to do with this fault, it was mentioned above.
The discussion revolves around a recurring issue with a 2007 Renault Kangoo 1.6 16V, where the immobilizer (immo) indicator remains lit, preventing the engine from starting despite the starter functioning. The user has checked the installation, mass points, and electrical connections, but the problem persists intermittently. Suggestions include replacing the ECU power control relay, checking the ignition switch ring, and performing diagnostics to identify potential communication errors between the engine ECU and the UCH. The user has also noted that the issue does not consistently trigger error codes during diagnostics, complicating the troubleshooting process. Other users shared similar experiences and potential solutions, emphasizing the need for thorough electrical system checks.
