[Solved] Renault Clio 3 / Grandtour - The wipers are not working properly
adriandj83 29985 6
  • #1 16637086
    adriandj83
    Rate: 16
    Hello, I have a problem with wipers in the Renault Clio 3 Grandtour 1.2. Well, some time ago they stopped responding to 1st and 2nd gear, they operate normally in 3rd gear. The car was bought in the showroom and is already 7 years old, there was no previous owner. It is very rare that they will turn on for the first or second gear but stop immediately, for example in the middle, and then they will not go any further. I am asking for help what may be wrong, if I need some information, please ask questions, I will answer for sure.
  • #2 16637276
    jarek225
    Help: 64
    Rate: 221
    Start by washing the contacts on the spider.
  • #3 16637291
    milejow
    Help: 1563
    Rate: 5149
    Disassemble the cowl, excavate the engine with the transmission, disassemble it and check the condition inside (especially brushes and windings). In the pit he likes to create an aquarium (through drained leaves) and the engine then sits half-submerged in water.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #4 16637787
    adriandj83
    Rate: 16
    I will let you know soon or if it will help.
  • #5 17024102
    szapoba
    Good day. Can you know what caused the problem? It's the same for me and I do not know what to do.
  • #6 17024501
    adriandj83
    Rate: 16
    Hello, the reason was the motorist, after his exchange everything is fine, greetings.
  • #7 17024504
    adriandj83
    Rate: 16
    Replacing the motor has solved the problem.
The Renault Clio 3 Grandtour wipers are malfunctioning, specifically not responding in the 1st and 2nd gear while functioning normally in the 3rd gear. Suggested troubleshooting steps include cleaning the contacts on the wiper motor and inspecting the motor's internal components, such as brushes and windings, for damage or water ingress. A follow-up indicated that replacing the wiper motor resolved the issue.
