Peugeot 508 Shallow 165mm Speakers: Morel Nano 602, Ground Zero, and Hertz EV Options
Orsoniasty 4380 2
  • #1 16293900
    Orsoniasty
    Hi
    The shallow 165mm speaker hole ... were supposed to be Morel Tempo 6, unfortunately they won't go in for the hell. They will fit Morel Nano 602, Ground Zero 165FX, Hertzy EV - these were the seller had in stock. Can anyone recommend any other flat mid-range speakers? Morel Nano is a bit of an inflection, I will gladly fit up to PLN 1000 per set. :)
    Thanks
  • #3 16294238
    Orsoniasty
    2 hours today, the men from the car audio company wasted time, because you can't mount anything there, so tight. Apparently.
