Choosing New 14 cm Speakers for Passat B5Fl to Match with JVC KD-R45 Radio
mafialosoo 19938 8
  • #1 16500604
    mafialosoo
    Rate: 19
    Hello. Due to the fact that my speakers are already to be replaced (because the membranes are already cracked) I would like to ask you for help in buying new 4 speakers forwards and backwards to the door. I have a JVC KD-R45 radio and I want to leave it. I will need 4 new distances and 4 adapters (plugs) for the exchange to combine low tones with tweeters. The diameter of the speaker, from what I measured was 14 cm and I would need such loudspeakers. Only what to buy to make it sound good to my radio?
    Please help. POZDRAWIA and nice every day!
  • #2 16500850
    adam_1991r
    Help: 83
    Rate: 154
    On the front you have 99% speakers with a total diameter of 16 or 16.5 cm and such search. Do not buy anything back, and invest the money saved in soundproofing the front. I recommend STP Gold mats from each other, although it is better for the dynemat. For the front I recommend Morel Elate 603. For this, the DLS A5 minimum amplifier. Once you buy a sub and you have fun :D Replace the radio with at least Alpine CDA-137bti :D
  • #3 16500907
    mafialosoo
    Rate: 19
    Thanks Adam for the answer. In this case, he does not plan any major investments. I have radyjko jvc about which I wrote and it is enough, original speakers played great but already the speakers cracked and farts .... I want to buy only the speakers and I just do not know what will be appropriate for my radio and which will also sound well ... I have a budget of 220 PLN per pair ...
  • #4 16500912
    adam_1991r
    Help: 83
    Rate: 154
    Then buy a set of Morel Maximo 6 and let it go. It will play better, and in the future you can buy something backwards as you will be missing. In this budget for 2 pairs will be really hard to find something that will play better than the series. Possibly GMS 965.
  • #5 16501323
    mafialosoo
    Rate: 19
    I have a budget of PLN 200 per 1 pair or 2 speakers. So for 2 couples I would like to spend PLN 400. ...
  • #6 16501327
    adam_1991r
    Help: 83
    Rate: 154
    It's better to buy one pair but better. At the top I also gave you budget proposals. And if you want to exchange everything, look for the original speakers. Because for PLN 200 it can play worse as a series in addition without soundproofing.
  • #7 16501330
    mafialosoo
    Rate: 19
    And do you know what speakers it mounts in the Passat b5 fl?
  • #8 16501672
    MietekFighter
    Help: 20
    Rate: 66
    Just in the Passat B5 acc. it would be best to look for the originals and buy all 4 speakers.
    Without sound damping, VW plays very well because the door has only two small diameter holes.
  • #9 16501732
    mafialosoo
    Rate: 19
    On the secondary market, it's hard for speakers in good condition ...
The discussion revolves around selecting new 14 cm speakers for a Passat B5Fl to pair with a JVC KD-R45 radio. The original speakers are damaged, prompting the need for replacements. Recommendations include considering the Morel Maximo 6 speakers for better sound quality within a budget of 200 PLN per pair. Users suggest investing in soundproofing, with options like STP Gold mats or Dynemat, to enhance audio performance. There is a consensus that original VW speakers may be the best choice, although they can be hard to find in good condition on the secondary market. The importance of sound damping is emphasized, as the vehicle's design limits speaker performance without it.
