MAN TGS 14.440 Gearbox: Recommended Oil Type and Capacity for Transmission
jarko2f 23328 11
What oil specification should I use in the gearbox?
Use transmission oil that meets MAN 341-Z5, MAN 341-Z4, or MAN 341-Z3 [#16295960] A more detailed recommendation given in the thread is 75W-80 API GL-4 gearbox oil meeting MAN 341 TYPE Z5, MB 235.41, and ZF TE-ML 02:E4 [#16296060] If the box has an intarder, there is also an oil filter under the flange; the cited filter numbers are 81.33215-0002 or 81.33215.0014 [#16299218][#16299372]
  • #1 16294853
    jarko2f
    Rate: 50
    Hello. Can someone suggest what oil should be flooded into the gearbox?
  • #2 16295868
    hubert04
    Help: 60
    Rate: 408
    what box?
  • #3 16295946
    jarko2f
    Rate: 50
    AS tronic 12AS 2131 TD
    • MAN TGS 14.440 Gearbox: Recommended Oil Type and Capacity for Transmission IMG-20170221-WA0001.jpg (157.49 KB) You must be logged in to download this attachment.
  • #4 16295960
    hubert04
    Help: 60
    Rate: 408
    The oil should be in the specification MAN 341-Z5 or MAN 341-Z4 or MAN 341-Z3
  • #5 16296060
    HADŻI
    Help: 87
    Rate: 441
    According to ZF, there is such a specification:
    Transmission oil (20L) 75W80 API GL-4; MAN 341 TYPE Z5; MB 235.41; ZF TE-ML 02: E4; EATON: VOLVO: 97307; Voith C
    • 12_as_2130_td-1.pdf (431.9 KB) You must be logged in to download this attachment.
  • #6 16297920
    jarko2f
    Rate: 50
    Hello and thank you for helpful hints but I have one more question about the filter for this chest has someone's number of the original Man
  • #7 16298999
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    To replace the filter, the chest must be removed.
    hubert04
    Help: 60
    Rate: 408
    it is a chest with an intarder so you have an oil filter under the flange that you break off the stitch on 13mm and pull it out MAN TGS 14.440 Gearbox: Recommended Oil Type and Capacity for Transmission
    HADŻI
    Help: 87
    Rate: 441
    As for the filter as above:
    • MAN TGS 14.440 Gearbox: Recommended Oil Type and Capacity for Transmission FILTR ZF.jpg (104.14 KB) You must be logged in to download this attachment.
  • #10 16374842
    bimbrownik43
    I currently use Revline in this model. Everything is flying as well as I recommend it to the right and left. Generally, it is now loud about this brand, primarily when it comes to their oils for heavy machinery :)
  • #11 18673000
    hehe_2288
    Rate: 71
    Hello. Colleagues, is there an oil filter housing in this box? I want to do the exchange myself and I don't know exactly where the filter is.
    The picture I added a preview. I have the same crate (I went in and checked that I have a retarder) but I have the same ending
  • #12 19097542
    arek888
    Rate: 14
    this looks like an output to a power take-off
The discussion centers on the appropriate oil type and capacity for the MAN TGS 14.440 gearbox, specifically the AS Tronic 12AS 2131 TD model. Recommended oil specifications include MAN 341-Z5, MAN 341-Z4, and MAN 341-Z3. A specific oil type mentioned is 75W80 API GL-4, which meets various standards including MAN 341 TYPE Z5, MB 235.41, and ZF TE-ML 02. Additionally, users discuss the oil filter replacement process, noting that the gearbox must be removed to access the filter, which is located under a flange. The original filter part numbers provided are 81.33215-0002 and 81.33215.0014. One user recommends using Revline oil for this gearbox model, citing positive performance.
