Seat Leon 3 (2014) 1.4 TSI 126HP - Fuse Diagram & 12V Cigarette Lighter Socket Solution
JJ theovin 13617 6
  • #1 16295493
    JJ theovin
    Does anyone have a diagram and description of the fuses for Seat Leon 3 2014 year 1.4 TSI 126KM? In the book I do not have this diagram and I have a non-working 12V cigarette lighter socket in the cabin. Thank you.
  • #3 17334043
    Bolo-Young
    Hey
    You can tell me which fuse in seat leon 3 2013 1.6TDI is responsible for the light in the trunk because it is not lit. There is light everywhere in the interior and the trunk does not shine. I can't find the pattern?
    thanks in advance
  • #4 17334125
    andrzej20001
    The lock's microst contact could fall or flap-body cables. I assume that the bulb is ok
  • #5 17334225
    Bolo-Young
    I will add that earlier the bulb has burned out of nowhere, and since then it has been off despite being replaced with a new lamp along with the bulb
  • #6 17335364
    andrzej20001
    Normal or LED bulb?
✨ The discussion revolves around the need for a fuse diagram for the 2014 Seat Leon 3 1.4 TSI 126HP, specifically to address a malfunctioning 12V cigarette lighter socket. A user provided a link to the Seat owner's manual, which may contain relevant fuse information. Other users discussed issues related to trunk lighting, suggesting potential causes such as a faulty micro switch or wiring problems, and confirmed the use of a normal bulb for the trunk light.
