2009 Seat Leon 1.9 TDI 105 HP Ecomotive Lift - Fuse Map/Box Diagram Needed (UK Version)
MojLeon 5529 4
  • #1 16700983
    MojLeon
    Rate: 13
    Hello, I just bought a Seat from the auction in the uk, it does not have any fuse at all, please help finding the fuse map for version 1.9 tdi ecomotive 105 km 2009.r lift, I was looking and nowhere else I found this model for other yes but I don't know is it the same Please help. best regards
  • #2 16701368
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, you have a fuse map on the back of the cover.
  • #3 16701502
    MojLeon
    Rate: 13
    if it wasn't I would ask for it :)
  • #4 16702563
    daro31ie
    Help: 366
    Rate: 650
    Fuses in the UK are a mirror image of the European version.
  • #5 16706968
    MojLeon
    Rate: 13
    Ok, I understand, but I can not find a map for the European version with the same parameters as I sent and I do not know if if I look at the 130 HP version or the 2.0 engine or on the octave this is a good diagram. Thank you greetings
