Seat Leon II 1.9TDI 105km 2006: Fuse Diagram & Engine Icon Solution for Correct Placement
patryq_dev 8403 1
  • #1 16449771
    patryq_dev
    Hello, I am looking for a fuse diagram for Seat Leon II 1.9TDI 105km 2006, the problem is that someone changed the fuses and you need to sort them out. I was looking for but I did not find a good diagram.
    In general, the car does not start, from what the mechanic said, the "engine" icon on the board is not displayed. The "start" method car starts and the problem lies only in the fuses.
  • #2 16449854
    decybel91
    Help: 1024
    Rate: 4231
    Since Golf5 there is an identical description, there are only two versions under the hood and two versions inside. You have to google fuses and adjust yourself.
