Seat Leon 2 2006 - Fuse Terminal 30 Burning, 20A Fuse in Engine Compartment, Error 00926
brylant238 16713 2
  • Request for 20A fuse circuit diagram and modules
    #1 16257647
    brylant238
    Rate: 44
    W skrzynce bezpiecznik w komorze silnika przepala się bezpiecznik 20A.
    W module komfortu jest bład 00926 - Terminal 30
    011 - Open circuit
    Jakie moduły zasila ten bezpiecznik. Poratuje ktoś schematem
    Auto normalnie odpala.
    Załączam skan VCDS
    Chassis Type: 1P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: VSSZZZ1PZ60071205 Mileage: 123520km/76751miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 06A-906-033-BGU.lbl
    Part No: 06A 906 033 FH
    Component: SIMOS71 1.6l 2VG 7004
    Revision: --H01--- Serial number: SEX7Z0H0000000
    Coding: 0000071
    Shop #: WSC 06401 785 00200
    VCID: 6ADB242A45DFE44E2A7-803F
    No fault code found.
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 P
    Component: ASR FRONT MK70 0105
    Coding: 0017025
    Shop #: WSC 06402 785 00200
    VCID: 3F8DA57E6EDDB1E6AD9-806A
    4 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    003 - Mechanical Failure - Intermittent
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1P0 907 044
    Component: ClimatronicPQ35 001 0302
    Shop #: WSC 00000 000 00000
    VCID: E9D9DB26C0D96F56A3D-80BC
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
    Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000000000000
    Coding: 008C0F2F00041000431D00000000000000017B075C400000000000000000
    Shop #: WSC 18434 020 328969
    VCID: 6FED353E7E3D01667D9-803A
    Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 110308 022 0601
    Coding: 00056208
    Shop #: WSC 18434
    1 Fault Found:
    00926 - Terminal 30
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 205
    Mileage: 123521 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 5.00 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
    Component: J234__A02 VW10 HI 1815
    Revision: 19013000 Serial number: 0039DPB4L4VZ
    Coding: 0012338
    VCID: 3B75D16E7AC5ADC6811-806E
    Subsystem 1 - Serial number: 6333FTS619193167
    Subsystem 2 - Serial number: 6343FTS635463167
    Subsystem 3 - Serial number: 6353ETS67U1USVNH
    Subsystem 4 - Serial number: 6363ETS6FDJTSVNH
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    1 Fault Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 205
    Mileage: 123521 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:59:11
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
    Component: J0527 634 0070
    Coding: 0002042
    Shop #: WSC 06441 785 00200
    VCID: 77FD0D5E066D49A6A59-8022
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    004 - No Signal/Communication
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1P0 920 827 D
    Component: KOMBIINSTRUMENT VO3 0450
    Coding: 0002101
    Shop #: WSC 11111 111 45725
    VCID: 3169F346A88957962BD-8064
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 P HW: 1K0 907 951
    Component: J533__Gateway H-- 0192
    Revision: H-- Serial number: 00000000000000
    Coding: E9801F060002020202
    VCID: 3467FA52579B62BE40B-8061
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VO3 0450
    1 Fault Found:
    00003 - Control Module
    000 - -
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
    Component: J386 TUER-SG FT 1129
    Revision: 31008001 Serial number: 00000052379005
    Coding: 0000176
    Shop #: WSC 04941 785 00200
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.065 H08 1901
    VCID: 3561C7565CE17BB6775-8060
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 CP
    Component: KSG 0401
    Coding: 99C000CC7F008505484B012004CC
    VCID: 800FE682D3A38E1E143-80D5
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
    Component: J387 TUER-SG BT 1129
    Revision: 31008001 Serial number: 00000011279004
    Coding: 0000176
    VCID: 3C77D2727FCBAAFE88B-8069
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1P1 035 186 B
    Component: Radio BVX 0006
    Coding: 0020414
    VCID: 2B55E12E8AA53D46111
  • #2 16257674
    Ireneo
    Help: 747
    Rate: 2472
    It will be easier if you enter the number of this fuse.
  • #3 16257702
    brylant238
    Rate: 44
    Fuse F10
    • Seat Leon 2 2006 - Fuse Terminal 30 Burning, 20A Fuse in Engine Compartment, Error 00926 Bezpieczniki.png (19.72 KB) You must be logged in to download this attachment.
