[Solved] Seat Toledo I 1997 1.9TDI: Fuse Scheme Needed - Lamp & Fog Lamp Diagram Requested
karo_1906 43941 2
  • #1 16714583
    karo_1906
    I need a lamp fuse scheme, and above all a fog lamp. Thank you in advance for your help :)
  • #2 16715397
    Pedros050
    Help: 2471
    Rate: 3927
    A relay box inside the car.
    fuses:
    A - electric seats
    B - not used
    C - electric windows
    D - not used
    E - rear windows
    F - alarm
    G - alarm, sound signal
    relays:
    R1 - fog lights
    R2 - rear hatch, release of the lock
    R3 - Immobilizer
    R4 - not used
    R5 - not used
    R6 - telephone
    R7 - electronic tachometer test (EPC) relay
    R8 - daytime running light system
    R9 - Taxi alarm, fuel pump
    R10 - Taxi alarm
    R11 - Immobilizer, reversing lights
    R12 - 30 voltage supply ends
    R13 - cooling fan
    1 - audio signal
    2 - output X
    3 - not used
    4 - glow plugs
    5 - clock relay for washing / wiping the windscreen
    6 - rain sensor
    Fuse box on the battery in the engine compartment
    1 - cooling fan
    2 - ABS
    3 - ABS
    FL1 - alternator - 110A or 150A
    FL2 - interior - 110A
    FL3 - cooling fan - 30A
    FL4 - motor control - 50A
    FL5 - glow plugs - 50A
    FUSE
    Receiver number:
    1 - Heated windscreen washers. heated mirrors 10A
    2- Direction indicators 10A
    3- Świat3a 5A
    4- License plate light 5A
    5- Applying the 7.5A comfort system
    6- Central locking 5A
    7- Świat3a reversing 10A
    8- Phone 5A
    9- ABS 5A
    10- Control unit for a 10A petrol engine
    11 - Dashboard 5A
    12- Additional power supply, diagnostic connector, telephone 7.5A
    13- Świat3a alloy 10A
    14- Interior lighting, central locking, electrically raised windows 10A
    Internal light 5A
    15- Dashboard, 5A automatic transmission
    16- Sp.13 electromagnetic electric water pump 10A
    17- Free 7.5A
    18- World3 passing, right 10A
    19- World3 passing, left 10A
    20- World road, right 10A
    21- world road. left 10A
    22- World positional, right 5A
    23- World positional, left 5A
    24- Windscreen washer pump 20A
    25- Heating, air conditioning 25A
    26- Rear window heating 20A
    27- Rear window wiper 10A
    28- 15A fuel pump
    29- Control unit for a 10A petrol engine
    30- Roof window 20A
    31- Automatic transmission 20A
    32- Injectors: 15A gasoline engine
    High-pressure 15A engine control unit
    33- Headlight washer system 20A
    34- Control unit for a 10A petrol engine
    High-pressure 10A engine control unit
    35- 30A trailer socket
    36- Front fog world3. rear fog light 5A
    37- Electrical socket 10A
    38- Trunk lighting, central locking / power windows 10A
    35- Emergency world3a 15A
    40 - 3-way signal. 20A
    41- Lighter 15A
    42- Head Unit 15A
    43- Control unit for a 10A petrol engine
    44- Heated seats 15A Seat Toledo I 1997 1.9TDI: Fuse Scheme Needed - Lamp & Fog Lamp Diagram Requested
  • #3 16723910
    karo_1906
    Thank you very much for your help :)
