Fenton SPB-12 PA Speakers: Good Investment for 40-60 People Events & Home Use?
Dixon9182 18759 11
  • #1 16297669
    Dixon9182
    I have a question for you regarding the columns ...
    Are the Fenton SPB -12 PA speakers a good buy for events for 40-60 people ???
    The speakers can also be used to listen to music at home and I want to connect them to my computer to get a better sound effect from games.
    If these columns are a bad solution, please send a link with others.
    Best regards! :)
  • #2 16301131
    sebap
    Help: 538
    Rate: 1078
    Generally, writing this is just a rubbish to match this theme.
    Please enter a budget.
  • #3 16302689
    Dixon9182
    I am looking for something so max to 700/800 PLN I do not want top-end loudspeakers ...
  • #4 16303050
    buczo11
    Help: 60
    Rate: 121
    Hello!
    Do you want to connect speakers via an amplifier, or do you prefer active speakers?
    Does the computer have a dedicated or integrated sound card?
    Returning to the (passive) speakers, look at the STX brand.
  • #5 16303725
    sebap
    Help: 538
    Rate: 1078
    The ones you gave the link to are not the bottom shelf. They are placed under the shelf, which are shelves for normal columns.
    With this budget it is only used equipment.
  • #6 16305093
    Dixon9182
    I have a dedicated sound card and I prefer active speakers.
  • #7 16317127
    buczo11
    Help: 60
    Rate: 121
    If you are interested in new equipment, I suggest Edifier R2600 in 2.0 system.
  • #8 16317999
    Dixon9182
    Rather, I am looking for something bigger
  • #9 16319453
    buczo11
    Help: 60
    Rate: 121
    In what respect?
    Are you able to increase your budget, and if so, how much?
  • #10 16323075
    Dixon9182
    And returning to these Fantonów what I wrote above is worth the price ??
  • #11 16323295
    sebap
    Help: 538
    Rate: 1078
    What did I write in the 2nd post?
  • #12 16330750
    PANICZKAMIL
    Help: 325
    Rate: 350
    Pseudo stage or stage will NOT play well at home, especially for games or movies. I have over 30kW sound system at home on stage (high shelf) and at home in the living room 2.0 system with a power of 2x100w and for a computer wireless headphones and some Logitechs. I tried everything from the stage at home and it does NOT work. PS Yes - I can "set up the equipment"
✨ The discussion revolves around the suitability of Fenton SPB-12 PA speakers for events with 40-60 attendees and home use, particularly for gaming. The original poster seeks advice on whether these speakers are a good investment within a budget of 700-800 PLN. Responses indicate a preference for active speakers and suggest considering alternatives like STX brand speakers or Edifier R2600 for home use. Concerns are raised about the performance of PA speakers in a home setting, especially for gaming and movies, with one participant sharing their experience of using high-end equipment at home and recommending against using stage speakers for such purposes.
