TP-LINK TL-WR841N: Upload OpenWRT Firmware - Hardware V11, MIPS, Atheros, QCA9533, 4MB Flash
piotrek751 18942 17
How do I flash OpenWrt-compatible firmware on a TP-LINK TL-WR841N v11 with QCA9533 and 4 MB flash?
Use a LEDE/OpenWrt image made specifically for WR841N v11, because the normal LuCI/OpenWrt build is too large for the router’s 4 MB flash. The forum points to the LEDE 17.01.0 ar71xx/generic downloads, which include three images for WR841Nv11, and says you can flash it from the stock firmware’s configuration menu after returning to the manufacturer software if needed [#16317131] LuCI itself could not be installed on this device because the installer reported too little memory available [#16298286] The original poster later confirmed that downloading the LEDE image from that link and flashing it worked [#16342492]
  • #1 16298024
    piotrek751
    Rate: 14
    Hello!
    Question as in the topic. How to upload the openwrt firmware to the router: TP-LINK TL-WR841N
    Information about hardware:
    Hardware version: V11
    Instruction set: MIPS
    Vendor: Atheros
    Bootloader: UBoot
    System-On-Chip: QCA9533-AL3A
    CPU Frq: 650MHz
    BogoMIPS: 432.53
    Flash-Chip: Spansion FL032PIF
    Flash size: 4MB
    RAM-Chip: Zentel A3S56D40GTP-50L
    Wireless: QCA9533-AL3A
    Switch: QCA9533-BL3A built-in
  • #4 16298098
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    So you do not have access to the GUI at all now? And through Telnet, SSH? Does the ping answer?
  • #5 16298128
    piotrek751
    Rate: 14
    He responds to ping
    You can not connect via telnet
  • #6 16298199
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    And is it visible as AP via WiFi?
    [Edit]
    Try your buddy yet connect via SSH (via putty, e.g.). Out of curiosity, I've now put OpenWRT on WR841 only v9 and will not let in SSH after the Telnet launch.
  • #7 16298214
    piotrek751
    Rate: 14
    No it is not visible but internet access is via lan
    Added after 5 [minutes]:
    I putty in the program, I logged in as root
    I entered two commands opkg update later, opkg install luci-ssl
    and now something is just still not like the interface
  • #8 16298253
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    And you turned on what you installed? I do not know how now, but when I was still having fun with Luci, after the installation, I had to fire the commands:
    /etc/init.d/uhttpd enable
    /etc/init.d/uhttpd start
    And you are sure that the package is called luci-ssl?
  • #9 16298277
    piotrek751
    Rate: 14
    After entering the opkg update command
    After entering the command opkg install luci
    Added after 4 [minutes]:
    After entering
  • #10 16298286
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    You can not fit Luci, the installer throws a message about too little memory available.
  • #11 16298297
    piotrek751
    Rate: 14
    So why the videos are shown and it is possible to upload the firmware from what he writes in the data about hardware, all versions of this router are to remember 4MB.
    I was able to upload to it other dd-wrt firmware I wanted to change, because in this firmware there is not even a logout button.
  • #12 16298304
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    It may Gargoyle throw him on him. I do not like the DD-WRT personally either.
  • #13 16298412
    piotrek751
    Rate: 14
    I am trying to upload gargoyle, but tp-link does not find the file with the firmware
    Added after 32 [minutes]:
    I changed the name to a shorter one and succeeded. How to embed Polish into this firmware?
  • #14 16300693
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    It can be downloaded in the System-> Package package with the PL language but there is nowhere in the GUI language changes. There is also Gargoyle-PL by Obsy but WR841Nv11 does not exist, unless I did not find it. And what about a distro from Luci, did you check LEDE? I just fired on WR841Nv9 because I have one at hand and Luci is in this picture.
  • #15 16311763
    piotrek751
    Rate: 14
    I tried it does not work, the same displays in the terminals as before on the screns
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I do not know how you tried to install it. On this site you have LEDE images (newer project from OpenWRT): https://downloads.lede-project.org/releases/17.01.0/targets/ar71xx/generic/
    There are three images for WR841Nv11, try to put one into your box, for sure go back to the manufacturer's software and install LEDE from the Configuration Menu.
  • LEDE image installation works on WR841Nv11
    #18 16342492
    piotrek751
    Rate: 14
    I've installed it, it works. All the time I tried to install openwrt luci instead of lede. I just downloaded the image from the link with the software and it works, the problem is solved. Thank you for helping me. 28
The discussion revolves around uploading OpenWRT firmware to the TP-LINK TL-WR841N router, specifically hardware version V11. The user initially faced issues accessing the router's GUI after attempting to upload the firmware via the LuCI interface. Despite being able to ping the router, they could not connect through Telnet or SSH. After some troubleshooting, they managed to log in via SSH and attempted to install the LuCI interface but encountered memory limitations. The conversation included suggestions to try different firmware options like Gargoyle and LEDE, with the user eventually resolving the issue by successfully installing OpenWRT after downloading the correct image.
