[Solved] Upgrading D-Link DWR-116 Play Firmware from V1.00 (PLAY) b06 2014 to Latest Clean Version
cyfu 10791 6
  • #1 17141683
    cyfu
    Rate: 20
    Is it possible to record pure soft to d-link dwr116 because I have an old one from playa V1.00 (PLAY) b06 from 2014 and I see that it is clean on the site from 2016. Well, unless somewhere newer from play I would ask because I can't find .
  • #3 17141859
    cyfu
    Rate: 20
    Which file to download for the P / N EWR116EPY .... A2E version
    And how it is recorded from the browser, enter 192.168.2.1 to the router menu, the device's tools / software tab and paste this file there
    Is this done through usb?
    And if everything will work, I am not currently using it as an internet provider but as an additional Switch.
    I also have tp-link. mr-3420 or you can also add something similar to it
    I found this site http://dl.eko.one.pl/firmware/
    makosuu
    Help: 369
    Rate: 371
    You can, but this router for modem support is the bottom. If you want to upload something to him, I recommend the latest gargoyle from gargoyle-router.com
    Just like that.
  • #5 17144601
    cyfu
    Rate: 20
    First, I uploaded the file with the A2PL extension and I was fortunate enough to fix the router.
    later I recorded with A2EU and I recorded mifi works.
    And if I would like to change to others now, how to upload, for example, LuCi or return to the original one. How to upload it now?
    makosuu
    Help: 369
    Rate: 371
    You are uploading a file with the name sysupgrade. And you have to look for OFW, but I don't know why you should go back.
  • #7 17145092
    cyfu
    Rate: 20
    http://eko.one.pl/?p=mifi
    Here in faq writes everything, I found.
    I think I can handle it
    Thank you very much and best regards.
The discussion revolves around upgrading the firmware of the D-Link DWR-116 Play router from an older version (V1.00 (PLAY) b06 from 2014) to a newer clean version available since 2016. Users inquire about the process of uploading alternative firmware, specifically mentioning LEDE with LUCI and Gargoyle firmware. Instructions include accessing the router's interface via 192.168.2.1 and using the device's tools/software tab for firmware upload. Users share experiences with different firmware versions (A2PL, A2EU) and seek guidance on reverting to original firmware or switching to other alternatives. Resources such as eko.one.pl are referenced for firmware files and FAQs.
