Setting Up TP-Link TL-WR841N as AP Client with Gargoyle Firmware: Connecting to WR1043ND Router
JEDD 14094 9
How can I configure a TP-Link TL-WR841N with Gargoyle to work as a wireless client/bridge to a WR1043ND so its Ethernet ports get internet access?
Configure the WR841N with Gargoyle as a wireless DHCP client and give it a LAN address outside the main router’s subnet, for example 192.168.2.1 when the WR1043ND is 192.168.0.1 [#16212708][#16208483] After flashing a new Gargoyle version, restore factory settings and reconfigure from scratch [#16210462] If it still will not connect, first test with encryption disabled on the main router [#16208438] One reply also recommends Gargoyle 1.9.1 specifically [#16210399] WDS was reported as working for internet and local access, but it may interfere with normal Wi‑Fi use on the main router [#16208632][#16210330]
  • Troubleshooting Gargoyle client bridge connectivity to WR1043ND
    #1 16208143
    JEDD
    Help: 170
    Rate: 241
    Hello. I am trying to set up this router in Client mode, but I can not get internet connection, or even locally.
    The main TP-Link TL-WR1043ND router provides internet for the whole house and I am also trying to connect to it. The IP of the main router is 192.168.0.1.
    In the additional (841) I have set wireless / bridge and there Bridge IP 192.168.0.2, mask 255.255.255.0, AP / Gateway IP 192.168.0.1, wan disabled, DNS the same as gateway.
    Then connect via client bridge, reapater disabled, operation mode B + G + N, channel width 20MHz, transmit power max, SSID to join , wireless channel 9, encryption WPA2-AES, password
    Despite my trying, I could not connect. I am interested in a functional ethernet port for internet and one for connecting a nc + decoder in a multiroom. Can someone tell me something more? Is the router for scrap?
  • #2 16208438
    bogiebog
    Help: 2569
    Rate: 1530
    On trial, disable encryption on the main router and try to connect.
  • #3 16208460
    JEDD
    Help: 170
    Rate: 241
    Adds a screenshot.
    • Setting Up TP-Link TL-WR841N as AP Client with Gargoyle Firmware: Connecting to WR1043ND Router Bez tytułu.jpg (425.2 KB) You must be logged in to download this attachment.
  • Bridge IP outside AP subnet becomes reachable after DHCP lease
    #4 16208483
    bogiebog
    Help: 2569
    Rate: 1530
    I have almost identical bridge settings on my 841, gargoyle 1.9.1
    except for the IP bridge in brackets, it says "(must be outside ap subnet)"
    firmware version?
    Added after 4 [minutes]:
    For my router: 192.168.50.1 a bridge ip 192.168.51.25
    I can not get to the router after 192.168.51.25 even if I set the computer ip at 192.168.51.222
    when I get IP from dhcp from 192.168.50.1 (via bridge) then I enter the bridga after IP which bridge got from dhcp 192.168.50.1 (eg 192.168.50.202)
    here he writes what is to be "insde" or "outside" in the IP bridge.
    Added after 23 [minutes]:
    However, I can enter the bridge after 192.168.51.25.
    tracert looks interesting, 2x IP from the same network
    [code:1:306d1d3416]
    $ tracert -d 8.8.8.8
    Tracing route to 8.8.8.8 over a maximum of 30 hops
    1
  • WDS connection works, but router access breaks after IP change
    #5 16208632
    JEDD
    Help: 170
    Rate: 241
    I returned to the TP-Link firmware wr841nv9_en_3_16_9_up (151030). Because I could not connect back to the router after changing IP from 192.168.0.2 to 192.168.1.1 (I wanted to see if it works like that). After the change I can not connect to the Connection tab, others work, for example, status, update, etc.
    I connected via WDS on the main and secondary router. For now it looks like the internet is working and the local connection is, I will wait if I lose the decoder permissions or not.
  • #6 16210330
    JEDD
    Help: 170
    Rate: 241
    Unfortunately, WDS is not a good solution because running this mode results in the inability to connect via Wi-Fi from the main router.
    I wonder why I can not enter the Connection tab when others are working, even after the device reset.
    Firmware version 1.7.0
  • #7 16210399
    bogiebog
    Help: 2569
    Rate: 1530
    upload gargoyle 1.9.1
    WDS should not exclude the AP mode, the whole idea of WDS, always with WDS is AP, otherwise the WDS idea would be different.
  • #9 16210462
    bogiebog
    Help: 2569
    Rate: 1530
    After uploading the new firmware, restore the factory settings and reconfigure.
  • #10 16212708
    CHACA
    Help: 875
    Rate: 457
    If you have 841 downloaded Gargoyle, set it to dhcp wireless and change the LAN address to 192.168.2.1.
The discussion revolves around setting up a TP-Link TL-WR841N router as a client bridge using Gargoyle firmware to connect to a TP-Link TL-WR1043ND router. The user is experiencing issues with internet connectivity and local access despite configuring the bridge settings correctly. Suggestions include disabling encryption on the main router, ensuring the bridge IP is outside the main router's subnet, and using DHCP settings. The user also attempted to revert to the original firmware and faced challenges accessing certain router settings. Recommendations include restoring factory settings after firmware updates and adjusting the LAN address to avoid conflicts.
