Alternative Firmware for TP-LINK WR841N v11 Router: Boost Connection from 72Mbps to 150Mbps
miko1282 6060 15
How can I restore the original TP-Link firmware on a WR841N v11 router running DD-WRT?
To restore the stock TP-Link firmware on a WR841N v11, use the DD-WRT webrevert package made specifically for that exact model and hardware revision, then flash it from the router’s web interface over a wired connection. [#16356947][#16356729] The file linked for this case is the WR841N v11 webrevert archive, so make sure you are not using firmware for a different version. [#16356947] Unpack the .rar first and upload the extracted .bin file, not the archive itself. [#16366322][#16371809] Before flashing, reset the router with the hardware button to clear saved settings; that only resets configuration and does not restore firmware. [#16368301][#16371837] If the upload stops around 13% and the router reboots, that points to a flashing issue such as the wrong or unprepared file. [#16356656][#16371809]
  • #1 16353430
    miko1282
    Hello everyone, I have a problem with the tp-link wr841n v11 router I installed ddwrt on it (I need it as a wifi relay) everything works but by connecting to it with a 150Mbps card the connection is up to 72Mbps regardless of whether I'm 30 cm from the router or 10m and 2 walls on below I have the same router only in v9 version (it was once ddwrt on it but without much problem I returned to the original Tp-link software) and when I connect to it I have full 150Mbps and clearly higher 30Mbps connection speed: 53Mbps. Would someone help me get back to the original soft? I have rather poor knowledge of computers and routers, but I'm learning :) Greetings.
  • #6 16356687
    bogiebog
    Help: 2569
    Rate: 1530
    Do you upload via cable or WIFI?
  • #7 16356729
    miko1282
    after the cable of course
  • #10 16366157
    miko1282
    Please help: /
  • #11 16366322
    jimasek
    Help: 3783
    Rate: 2681
    . @ miko1282 - File unpacked?
  • #12 16368301
    KOCUREK1970
    Help: 3862
    Rate: 5490
    @ miko1282
    jimasek wrote:
    File unpacked?
    It is also worth resetting the router with the button on the housing (it will return to the default settings).
  • #13 16371809
    miko1282
    of course, the unzipped file (upload bin) button will actually reset the router settings but will not restore to the original firmware
  • #14 16371837
    KOCUREK1970
    Help: 3862
    Rate: 5490
    miko1282 wrote:
    the button will actually reset the router settings but will not restore to the original firmware
    This is not his role in this list - it is to clear the settings saved in the current configuration, and prevent the next update from stalling (which unfortunately happens).
  • #15 16372090
    miko1282
    So how do I upgrade?
  • #16 16414974
    miko1282
    Subject to close, problem solved.
The discussion revolves around issues faced by a user with a TP-LINK WR841N v11 router after installing DD-WRT firmware. The user reports a maximum connection speed of 72Mbps despite using a 150Mbps network card, contrasting with a WR841N v9 model that achieves full speed. Various responses suggest troubleshooting steps, including ensuring the correct firmware version is downloaded, using a wired connection for updates, and resetting the router to default settings. The user experiences difficulties during firmware updates, with failures occurring at around 13%. Ultimately, the problem is reported as resolved, although specific solutions are not detailed in the final messages.
