Makita DC10WA charger - R2 and R3 resistors, replacement for MIP3E5MY transistor
linek27 24066 13
How can I replace the damaged MIP3E5MY in a Makita DC10WA charger, and what are the values of the unreadable R2 and R3 resistors on the high-voltage side?
Replace the damaged MIP3E5MY with MIP3E7MY; it was reported as a working substitute and is available from electronics stores [#16340953] R2 and R3 are both 1 Ω resistors and are connected in parallel [#16340953] One reply also noted that the MIP3E5MY is not a MOSFET but a converter device, and that MIP3E4 is weaker than MIP3E5 [#16298986]
  • #1 16298512
    linek27
    Rate: 22
    Makita DC10WA charger (7.2V - 10.8V Li-Ion) designed to charge Makita screwdriver batteries. Mosfet - MIP3E5MY was damaged. Please help me choose a replacement for the above. transistor. I guess you can only buy the original directly from China? Moreover, the SMD resistors R2 and R3 on the high voltage side are illegible and therefore I am asking you to provide their values.
  • #2 16298521
    pawlik118
    Help: 202
    Rate: 609
    Show me a photo of the entire board, maybe I have one that works.
  • #3 16298607
    linek27
    Rate: 22
    Here you are.
  • #4 16298659
  • #7 16299222
    linek27
    Rate: 22
    Thank you for your help. Unfortunately, the original can't be obtained. I will try MIP3E4MY and possibly MIP2E5DMY. Only those illegible resistors. Maybe some hints?
    pawlik118
    Help: 202
    Rate: 609
    You probably need to draw a part of the diagram of this converter with these illegible resistors and select them based on the documentation of the converter controller.
  • #9 16308112
    linek27
    Rate: 22
    I`ve already done that. The only problem is that the MIP3E5MY element in the executive diagram does not include these resistors. This means there is a direct connection to ground without any resistance. And be smart here.
  • #10 16308633
    pawlik118
    Help: 202
    Rate: 609
    As for the repair - it is difficult to help without a piece of the diagram with the circuit with these resistors.
    As for your last entry, having basic knowledge about the operation of FLYBACK power supplies, you can more or less determine what resistors are supposed to be there. Without a diagram drawn from the board, it is difficult to guess the values. Show the diagram you drew.
  • #11 16309475
    linek27
    Rate: 22
    Schematic please.
    Sometimes it`s nice to fix something yourself and learn something else. What about these resistors?
  • #12 16310390
    pawlik118
    Help: 202
    Rate: 609
    Also send a view of the board from the elements side. The diagram shows that the resistors are mounted differently than usual.
  • #13 16311811
    linek27
    Rate: 22
    Exactly different. Picture please.
    Makita DC10WA charger - R2 and R3 resistors, replacement for MIP3E5MY transistor20170227_2..625.jpg (1.23 MB)You must be logged in to download this attachment. Makita DC10WA charger - R2 and R3 resistors, replacement for MIP3E5MY transistor20170227_2..639.jpg (4.18 MB)You must be logged in to download this attachment.
  • #14 16340953
    linek27
    Rate: 22
    Charger repaired. For posterity, the MIP3E5MY converter chip was replaced with MIP3E7MY. It is available in good electronics stores. Resistors R2 and R3 have values of 1 ohm and are connected in parallel. I guess that`s it. Topic to be closed.
The discussion revolves around the Makita DC10WA charger, specifically addressing the replacement of the damaged MIP3E5MY MOSFET and the illegible values of SMD resistors R2 and R3. Users provided insights on potential replacements, with MIP3E4MY suggested as an alternative, though it has different specifications. It was clarified that MIP3E5MY is a converter, not a standard MOSFET, and the original part is difficult to source. Ultimately, the charger was successfully repaired using the MIP3E7MY converter chip, with R2 and R3 identified as 1-ohm resistors connected in parallel. The discussion emphasized the importance of circuit diagrams for accurate repairs.
