Water Leak in Peugeot 307 SW 1.6 16v 2003: Driver's Side Floor Wet - Possible Causes
dawidof2024 29952 16
Why does water get onto the driver’s side floor of a Peugeot 307 SW 1.6 16V (2003) after rain, and where should I look for the leak?
The reported cause was blocked sunroof drain channels/gutters: water collected there, then ran through the car and seeped into the floor under the driver’s seat when it rained [#17460049] Before finding that, others suggested checking the drains under the wiper arms/plastic cowl for debris and making sure all drain passages are clear [#16304716] Other possible leak points mentioned were the door vapor barrier/foil, door seals, and wiring or technical bulkhead openings, but the confirmed fix in this case was the sunroof drainage path [#16330015][#16300789]
  • #1 16300550
    dawidof2024
    Rate: 44
    Hello. I have such a small problem ... as soon as it rains a little rain ... under the doormat from the driver's side the whole floor is wet ... I have heard from the mechanic that there are often such faults in the Peugeot, that this water somehow flows ... only without sense to look where, because the car is too much to undress ...
    some say that from the bottom ... other that from the panorama ... yet another that from the air conditioning system ...
    did anyone have such an adventure ???
    my model is peugeot 307sw 1.6 16v 2003.
    from the air-conditioning rather not because the floor is not oily as it touches ...
    and searching for the error method will consume some penny ...
    so ... had such a fault? and if so ... what is the reason?
  • Controlled water test to trace the leak source
    #2 16300789
    g107r
    Help: 811
    Rate: 995
    Get two people in a washcloth, unless you have your own. One person pours a stream through the car, the other in the middle trying to locate which way flies water.
    It can fly with door seals, under the shaft, for example, badly glued glass, fuels, where often the outflows of "garbage" from trees clog.
    Joints of the body in this area, as well as by sealing electric bundles, cables, and other things passing there through the bulkhead from the cabin to the engine compartment.
    It's best to make your own rain and look from where it's flying, only then deeply undress looking for a hole.
    There are no tips on the forum of this car? Because on "my" are, and the car is already quite hard worked out by users.
  • #3 16303556
    dawidof2024
    Rate: 44
    it can not be checked ... from the heater as if it was flying so it would be sticky on the upholstery ... and it is wet. and it is typically wet under the doormat ... and only when it's raining. if it was visible from where it flies, I would not ask :) ... the mechanic said that many peugeots have this way ... hence my question to people who had this adventure ...
    and as I wrote, it is not art to pick up a car and look for it by trial ... and the specific advice needed ...
  • #4 16304716
    m789
    Help: 23
    Rate: 56
    Remove the wiper arms then plastic cage and check if there is no muck, look for drains check for patency.
  • #5 16304751
    jenusz11
    Help: 33
    Rate: 196
    it is poured in most often through the removed fole in the door under the upholstery
  • #6 16329854
    dawidof2024
    Rate: 44
    I checked it was not ...
    Added after 59 [seconds]:
    what is flooding in ???? what's the dissapointed bottom for the upholstery ???
    I do not understand..
  • #7 16329901
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Check where it is coming from, whether drops hang on the wires under the steering wheel, etc.
  • #8 16330015
    jenusz11
    Help: 33
    Rate: 196
    when you remove the upholstery from the door, there should be under it a foil glued to the door, which prevents the water from pouring in through the glass
  • #9 16376778
    dawidof2024
    Rate: 44
    it's only a wet wiper ... under the driver's shoes. you can not see where you are going.
    it's always wet after rain ... I thought someone had a peugeot and the same problem ...
    instead of taking off the car and looking for the reason ...
  • #10 16378352
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    I have a predecessor, and as I was flying that the wiper was wet, there were drops of water hanging on the wires under the fuse box.
    As you can not see anything ... Do not expect that someone accurately tells where the water is coming from.
    Water does not stand on the door seals?
  • #11 16968724
    dawidof2024
    Rate: 44
    unfortunately, we could not find a fault. most likely leaking from the glass or from the panorama ... but I did not undress it.
    mechanical breakdowns fall off ... because there are no leaks in the car.
  • #12 16968751
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    dawidof2024 wrote:
    not to take off the car and look for the cause
    Yes, because who is looking to punish you but how the floor will rot will be ola-god how it happened so you want to come to this or not? Because maybe someone has something like that, they have individual cases, but if you do not want to, you're waiting for a good luck.
  • #13 16968769
    dawidof2024
    Rate: 44
    SENS IN THAT NOBODY WANTED TO HELP ...
    there is no leakage from the radiator, there is no leakage from the air-conditioning system ...
    so the roof or glass panorama is left ...
    none of the mechanics wants to play cat and mouse ...
    so why should I keep fast if nobody can write that he had such situations and where to look for a problem ...
  • #14 16968793
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    And the cowl checked? All technical holes.
    What to sell? Because I do not want to look for myself. Or I will ride in rubber boots and whatever :D
  • #15 16968842
    dawidof2024
    Rate: 44
    So checked. leakage inside also checked and nowhere has leakage ... so just cut the glass and re-paste ... or panorama is leaking ... and again it is not so wet that in rubber boots .. ehh
    Why stupid answers ???
    I guess the finished topic is finished since no one helped.
    and the car does not sell because what for?
  • #16 17460049
    dawidof2024
    Rate: 44
    PROBLEM SOLVED!!! WATER WAS IN THE SUMMER ... INSTEAD THE CHANNELS FLY THAT HE WAS FLYING THROUGH THE CARRIAGE AND THAT the water was there and as the rain fell then it permeated the floor under the driver's seat. and professionals like not a panorama is a window for replacing railings ... and here is the number ...
  • #17 18046208
    valdi75
    Rate: 49
    I dig out the topic because I have the same. Will you give Kolego some details where and how to look?
The discussion revolves around a water leak issue in a 2003 Peugeot 307 SW 1.6 16v, specifically on the driver's side floor, which becomes wet during rain. Various potential causes are suggested, including faulty door seals, clogged drainage channels, and issues with the panoramic roof or windshield. Users recommend checking the wiper area for debris, ensuring the door's protective foil is intact, and inspecting the drainage systems for blockages. One user eventually identifies that the water was entering through improperly functioning channels, leading to the wet floor condition. The conversation highlights the commonality of this issue in Peugeot vehicles and the challenges in diagnosing the source of the leak without extensive disassembly.
