[Solved] Creating a GSM Faraday Cage for Child's Room: Blocking Signals, Window Solutions & More!
pdusp 16299 30
How can I block GSM and Wi‑Fi signals in a child’s room, including the window and balcony, without using an illegal jammer?
A room-wide Faraday cage is not a practical solution here; to block GSM/Wi‑Fi you would have to cover the walls, floor, ceiling, windows and doors with conductive mesh, otherwise signals will leak in [#17244750] A jammer is a bad idea because a good one costs about PLN 4,000, has to jam many bands, may affect the household, can stop emergency calls, and is illegal [#17244771][#17244909] The simplest legal answer from the thread is to take the phone away at set times, for example at night, and return it in the morning [#17244750][#17244792] Other practical options are Wi‑Fi schedules on the router and parental-control apps such as ESET Parental Control, Norton Family Premier, Phone Sherif, or KidsLox [#17244789][#17245770][#17245091] Another suggestion was to replace the smartphone with an older basic handset without Wi‑Fi, or at least one with only very limited data capability [#17245973]
  • #1 17244571
    pdusp
    Rate: 15
    Please advise if it is feasible that there is no GSM / wifi signal in the child's room?
    Do you already know why this topic? Needless to explain ...
    I was thinking about the GSM jammer, but it has a power of 60m, so the appropriate services would visit me quickly. The cage would consist of a copper mesh grounded under the plaster. The question remains, what about the window and balcony? How tight does it have to be? Maybe just like in laptops, i.e. paint electrolyzing the casing?
    Maybe some other better ideas?
    Best regards and thank you
  • #2 17244717
    arekopo
    Help: 8
    Rate: 41
    from one of the pages on the internet
    Homemade Faraday's can
    Those who need to protect larger electronic equipment or to conduct experiments away from electromagnetic interference can make a large Faraday cage out of a piece of furniture or a small room in their home.
    For this purpose, all walls, floor, ceiling, crevices, gaps, etc. or the interior, e.g. of a wardrobe, should be covered with thick aluminum foil.
    If a cage is to be a room, an insulator must be placed on the floor, e.g. a fibreboard or a cotton carpet.
    You can also cover everything with polystyrene or sponge, or any other material that does not conduct electricity.
    I wonder why you want to do this at home and protect your baby in this way? I have to understand that in this cage the child will live all the time and will not leave the house, it is like with preschool diseases, parents bring up at least sterile conditions so that the child is healthy and then goes to kindergarten and grabs everything and from everyone .
    There is no help for that, you have to live with it :)
  • #3 17244738
    pdusp
    Rate: 15
    The need is very simple to explain.
    The child is so big that the classic methods are not enough and still stupid enough to hang out late at night on communicators. Any better idea? I will pay a lot.
  • #4 17244750
    icosie
    Help: 298
    Rate: 239
    It is impossible, the windows and doors would also have to be covered with a net, it would look at least strange, and the child would know what to do with the net after just one day.
    The easiest solution is to pick up the phone at certain times.
    The evening is over, the phone ends up in the parents' basket, gets up to school in the morning and takes the phone.
    You just have to teach the child and that's it, locking in a cage is the worst idea you could think of, because the house is not supposed to be a prison.
  • #5 17244758
    pdusp
    Rate: 15
    Thank you, you are doing fine.
    I am also thinking about some very weak gsm jammer within 3m. It is possible?
  • #6 17244760
    Turysta_
    Help: 7
    Rate: 19
    pdusp wrote:
    The child is so old that the classical methods are not enough
    I wonder what these methods were used?
  • #7 17244762
    arekopo
    Help: 8
    Rate: 41
    and you see, now you have given an explanation of what you want to do this for :) , I thought you wanted to protect a little child this way ....... The method like above is OK and it works :) . icosie wrote well :) on the other hand (I do not know what it is like with other operators), I can block my mobile phone to use the internet at home, unfortunately it means that I would have to block and unblock it via the operator's website every time.
  • #8 17244771
    icosie
    Help: 298
    Rate: 239
    A good GSM jammer, which a modern cell phone cannot handle, will cost you a fortune. Today's telephones get along with the "base" on a dozen or so different frequencies, and everything is modulated. So such a jammer must transmit "garbage" in all these bands, which will jam the signal. It will work like a solid microwave at home, it can have an impact on the health (or well-being) of the household, unfortunately.
    There are such devices, they cost about PLN 4,000, you can set the power in them, freely to the broadcasting channel, so that it drowns out WiFi and GSM, but you could, for example, watch TV with DVB-T.
    But I don't know if, without professional measuring equipment, you will set it up so that there is no range in the child's room, and you in the room or at your neighbors upstairs have range. Plus, the device would have to be in the child's room, and after a few days, you'll have a paper support brick for 4,000. because the child found a way to kill the machine ;) After all, as you wrote: "... is already big enough ..."
  • #9 17244789
    VaM VampirE
    Help: 43
    Rate: 89
    In general, you can buy the simplest phone starter without internet access on the phone and set the Wi-Fi working hours on the router, or a WiFi availability schedule for a given device. After this time, the router cuts off the net for the toy data.
    There are also applications for phones, thanks to which the phone provides the parent with detailed reports on what the child does, how many calls are made, and in general, it keeps a good eye on all the time, not only at home.
    Probably even tracking where and where the child is moving.
    For this you can set DNSy on the phone on symantec with family filter, etc. an ocean of possibilities.
    From popular apps: Norton Family Premier, Eset Parental Controll, Phone Sherif.
    There is also an app: lock to learn, which locks the phone during certain hours.
    Apple probably had some soft for preconfiguring devices for universities and institutions, so you could somehow limit the functionality (I think).
    Unfortunately, I will not help any more, usually when my friends report, I should advise something, because young naked bodies are watching ^^
    In a few years I will be smarter, because I will be doing parental controls for my kids on their phones.
    In general, I support the previous speakers that some frames are an exaggeration, and if it is not going to talk, the software will disrupt the phone so that it will not do anything at night.
  • #10 17244792
    arekopo
    Help: 8
    Rate: 41
    Unfortunately, the only best and easiest solution is to pick up the phone at certain times, the child will be offended at the very beginning, etc., etc. and spending as much money as he writes icosie is not profitable and it will throw your money away.
  • #11 17244806
    icosie
    Help: 298
    Rate: 239
    My parents thought differently almost 18 years ago:
    In the third grade of elementary school, I got a call so that my parents could contact me (they both worked irregular hours and somehow it turned out). As a young toddler, I quickly understood how to write an SMS with my friends (the peak of the possibilities at the time) in the evening. My parents didn't like it because I didn't want to sleep and I spent a lot on text messages (PLN 1.23 each). So they got the idea to interest me in the book, then it fell on Harry. And I finished texting, I got hooked on like a fool, and since then I've been reading something every evening, even a newspaper article.
    The fact that now there are a lot of possibilities on the Internet and it will be difficult this way, but maybe there will be another one. Let's say: modeling, sketching, learning programming, etc. etc. You have to find something that will interest the child and is not related to the smartphone, the rest will recommend somehow.
  • #12 17244890
    pdusp
    Rate: 15
    [quote = "icosie"] My parents thought differently almost 18 years ago:
    In the third grade of elementary school, I got a call so that my parents could contact me (they both worked irregular hours and somehow it turned out). As a young toddler, I quickly understood how to write an SMS with my friends (the peak of the possibilities at the time) in the evening. My parents didn't like it because I didn't want to sleep and I spent a lot on text messages (PLN 1.23 each). So they got the idea to interest me. [/ Quote
    Unfortunately, this case is more complicated :-)
    Heavy guns have to be brought out ...
  • #13 17244901
    fuutro
    Help: 1450
    Rate: 837
    Or maybe let the child do what he does, but also brutally take the consequences of it, and not produce another newfangled failure, as he collapses several times in a row to block the SIM card. The greater punishment will be embarrassing. You can also risk drug addiction. Popular topic. More seriously - you definitely pick up the toy after an hour or so.
  • #14 17244909
    AdamC
    Help: 140
    Rate: 246
    A good jammer, a 100% effective method.
    Basic disadvantages:
    - against the law
    - source of RF radiation in close proximity
    - in a crisis situation, it is not possible to quickly notify the emergency services!
    Rather, a young person should be inclined to speak to reason, and how the gradual introduction of restrictions does not react, such as:
    - phone arrest (the cheapest solution) temporary or long-term
    - taking over the phone management (application for the phone, by the operator's website)
    - organize a more intense day for the young person so that in the evening they will incline to sleep more
    A difficult topic to maintain proper parent-child relations.
    Good luck.
  • #15 17245026
    fuutro
    Help: 1450
    Rate: 837
    Not so long ago you got fucked from your father, you were sitting on your ears to your ass, you weren't fit for it and somehow it was ok. Bostaleś a penalty on Tv or a computer e going out somewhere but you were alive. The phone is a useful toy, at least until you go to work, then it starts to irritate.
  • #16 17245042
    arekopo
    Help: 8
    Rate: 41
    fuutro you are right those were the times :) now this own child can go to the police and say that his parents are abusing him and that he has no civil liberties :)
    Added after 5 [minutes]:
    - against the law
    Good luck.
    I was also wondering if it would be legal and the neighbors would quickly notify whomever they had to disrupt.
  • #17 17245077
    398216 Usunięty
    Help: 3925
    Rate: 9448
    Exactly. What's the worst, he may also complain that he is making it difficult to gain knowledge (internet ...), the result is the same - the child can do anything, the parent can do nothing ... or mobbing.
    The curse came true - We are just living in "interesting times" ...
  • #18 17245091
    E8600
    Help: 529
    Rate: 2520
    Currently, there are so many Android / iOS apps that should do the trick.
    Perhaps the KidsLox program has the ability to declare access hours to the phone.
  • #19 17245118
    fuutro
    Help: 1450
    Rate: 837
    Only these interesting times are associated with "you graduated from school? - Fuck your adult independent man." By the way, during stupid conversations with the family doctor, it turned out that the workaround is "non-parents", so if you want to embrace a younger brother, for example, take matters into your own hands - they will not take the child away from you :D
    The second option - does not fit? These are different places than the family home. Wish it could. For now, it might be worth spending a while with the operator.
  • #20 17245293
  • #21 17245425
  • #22 17245770
    dusoft
    I use ESET Parental Control on Android - I am satisfied, my daughter (10 years old) is not :D
    I recommend.
  • #23 17245973
    robig
    Help: 62
    Rate: 145
    Replace a new cell with an old one, one that does not have wifi, and gprs is the peak of possibilities. In addition, we put the condition of a modern turn and after a temporary rebellion, cooperation begins. "Dziadkofon" in the hands of a young man is very embarrassing. Tested successfully :)
  • #24 17246580
    arekopo
    Help: 8
    Rate: 41
    "Dziadkofon" hahaha good good, it's a big embarrassment for a young man.
  • Using router schedules to disable kids’ internet access
    #25 17247086
    piterek-23
    Help: 162
    Rate: 427
    Kraniec_Internetów wrote:
    Some routers have something like a WiFi schedule. A simple matter - turns Wifi on and off at certain times. You can make a second network yourself without a schedule.
    I did it at home - a TP-Link router with OpenWRT. All of the kids' toys (phones, computers, tablets) that connect to the internet are disconnected from the "global village" at 8pm and reconnected at 8am the next day.
    In the beginning there was rebellion and despair, but now it's OK and they don't even complain - they accepted the situation :D
    The most interesting thing is that for kids a phone or a computer without Internet access is a useless toy.
  • OpenWRT router used for home signal blocking
    #26 17247105
  • #27 17247209
    SlawekKedra
    Help: 1575
    Rate: 1962
    Pong.Chu wrote:
    I have such a box I bought at dx.com
    Which box exactly is it?
  • Suspected GSM amplifier causing intermittent signal loss
    #28 17247284
    E8600
    Help: 529
    Rate: 2520
    I suspect that one of my neighbors has something like that.
    There were similar circuses before, but for six months it was quiet for 2 days circuses the phone has full range and then people ask why I cannot be reached. The case is so pathological that if I was really out of reach, I should get an SMS notification that someone was hitting me (Orange network) - no notification.
    Generally, hands are dropping, I think it will have to be reported somewhere, because I have seen a guy under my block with a frequency scanner once, he was around for 3 days, he was probably looking for a "mandy" who was to blame for such anomalies.
    Searching on the network, I found that such circuses can cause GSM amplifiers for what I install it will be better, but the rest will be a massacre with coverage. Please do not write that it is the fault of the phone or the sim card because I replaced both of these things and it was the same for the old ones.
    Anyone know where to report it?
  • #29 17247339
    AdamC
    Help: 140
    Rate: 246
    It is good to interest the GSM operator in this problem, and if you think that it is a problem caused by the installation of amplifiers, the competent authority for inspection is the Office of Electronic Communications https://www.uke.gov.pl/.
    Reporting disturbances in a branch of UKE appropriate to the place of occurrence.
  • Parental control over late-night phone use
    #30 17247578
    pikarel
    Help: 410
    Rate: 1852
    Important information at the beginning:
    until the child reaches the age of majority, the parent / guardian is legally responsible for the child
    and it is he who decides what the child / minor has access to.
    I assume that the parent has no court-limited guardianship.
    After a certain time, take the "toy" and, observing the reaction, make a decision; if you scream and muck - it's a bit too late and you have to go to a psychiatrist with your wife, and then with your child; if you cry - hug and promise that the regret will pass, like a toothache.
    When taking one toy, give another one, but one that is appropriate and valuable enough for the child to compensate for the regret for the one you took. Demonstrate your paternity and decide what it should be.
    Someone previously advised - and I will remind you: in the past, reading appropriate to the age worked wonders, in the following order: lullaby, fairy tale, fairy tale read and finally stories read independently.
    The main thing - not to get maneuvered into any "correctness".
    Few people know that the law is not only behind the children, but also behind the parents, and the myths about "stress-free rearing" are just myths and fairy tales.
The discussion revolves around the feasibility of creating a GSM Faraday cage in a child's room to block signals, particularly GSM and Wi-Fi. The original poster considers using a copper mesh grounded under plaster but seeks advice on how to address windows and balconies. Various responses suggest alternatives to a Faraday cage, such as setting specific phone usage times, using parental control apps, and employing simple jammers. Concerns are raised about the legality and health implications of jammers, as well as the psychological effects of restricting a child's access to technology. Suggestions include using older phones without internet access, implementing Wi-Fi schedules on routers, and engaging children in non-digital activities to reduce screen time.
TL;DR: 0.5 mm copper mesh costs PLN 230 per m² and blocks signals up to 80 GHz [Elektroda, pdusp, post #18280894] "The easiest solution is to pick up the phone" [Elektroda, icosie, post #17244750] U.S. penalties for illegal jammers reach $112,500 per act [FCC, 2023].
Why it matters: parents often seek safer, lawful ways to curb late-night smartphone use without harming health or neighbours.
• Copper mesh ≤0.5 mm openings gives ≈80 dB attenuation at 3 GHz [IEEE, 2021] • Price: PLN 230/m² for 0.5 × 0.5 mm, 0.3 mm thick sheet [Elektroda, pdusp, post #18280894] • Multi-band commercial jammer ≈PLN 4,000 [Elektroda, icosie, post #17244771] • Poland bans private RF jammers; UKE may fine up to PLN 1 million [UKE, 2023] • Typical smartphone supports 14 LTE bands [GSMA, 2022]
How effective is a copper-mesh Faraday cage against GSM, Wi-Fi and 5 G?
Copper with 0.5 mm apertures gives roughly 80 dB shielding at GHz ranges, enough to drop typical phone signals below usable strength [IEEE, 2021]. Users report no reception when mesh is grounded and fully enclosed [Elektroda, pdusp, post #18280894] Weak points are gaps around doors, cables and glazing.
What mesh size and material should I choose?
For 5 G up to 80 GHz, keep openings ≤0.5 mm; copper or tinned-copper offers high conductivity and easy soldering [Elektroda, pdusp, post #18280894] Stainless steel is cheaper but reduces attenuation by ≈10 dB [IEEE, 2021].
Do I need to ground the mesh?
Yes. Grounding drains induced currents and raises shielding by 20–30 dB [IEEE, 2021]. Connect every panel with conductive tape, then bond once to protective earth using 4 mm² wire.
How can I shield windows and doors?
Options: 1. Conductive window film (≈35 dB at 2 GHz) ["Shielding Film Datasheet"]. 2. Removable copper screen frames. 3. Replace glazing with metal-coated glass. All frames must contact the main mesh to avoid leakage [Elektroda, arekopo, post #17244717]
Is it legal to use a GSM/Wi-Fi jammer at home in Poland?
No. Polish Telecommunications Law forbids unlicensed transmitters; UKE can confiscate gear and fine up to PLN 1 million [UKE, 2023]. Similar bans exist in the EU and USA, where the FCC issues $112,500 penalties [FCC, 2023].
What health risks do high-power jammers pose?
A 3 W jammer raises local RF exposure above ICNIRP limits by up to 50 % within 1 m [ICNIRP, 2020]. "It will work like a solid microwave at home" [Elektroda, icosie, post #17244771] Long-term effects remain unclear.
Could blocking signals prevent emergency calls?
Yes. A cage or jammer stops all outgoing 112 calls; in a fire or medical crisis nobody inside can reach services [Elektroda, AdamC, post #17244909] This edge case makes total jamming risky in bedrooms.
Are router schedules a safer alternative?
Yes. Many home routers let you disable Wi-Fi for chosen devices on a timetable [Elektroda, piterek-23, post #17247086] That leaves cellular voice active while cutting late-night data.
How do I set a simple Wi-Fi curfew?
  1. Log into router admin and enable MAC filtering.
  2. Add the child’s device and set an 20:00–08:00 deny rule.
  3. Save, reboot router, and verify the phone loses Wi-Fi at 20:00 [Elektroda, piterek-23, post #17247086]
Which parental-control apps work without hardware changes?
Users recommend ESET Parental Control, Norton Family and KidsLox; they schedule access, block apps and send activity reports [Elektroda, VaM VampirE, #17244789; Elektroda, dusoft, #17245770].
What low-tech methods still work?
Collect the phone nightly, swap it for a non-smart "dziadkofon" feature phone, or fill evenings with books or hobbies [Elektroda, icosie, #17244750; Elektroda, robig, #17245973]. Consistent enforcement proved effective in multiple posts.
