Understanding Audi A6 C7 - S-tronic 0B5 Transmission: Electronic Tapes and Solenoids
adam_sil 7422 3
  • 0B5 electronic tapes: wiring-only or embedded electronics?
    #1 16305879
    adam_sil
    Help: 14
    Rate: 88
    The case is 0B5 S-TRONIC. I have a question: are these electronic tapes that connect the controller with solenoids just the wires that connect the controller pin with the appropriate solenoid contact, or is there any electronics sunk there? If it's an ordinary tape, checking the transition is best with a light bulb that should be lit on each contact, right? In addition to the contacts for solenoids, the smaller one has a fused sensor. Do any of you colleagues have any knowledge about this? The tape numbers are: 0B5.927.413 - the larger one and 0B5.927.807 - the smaller one
    Thanks for the answer
    Regards
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    The shorter one includes the clutch oil temperature sensor (G509) and the gearbox output sensor (G641). In the long one there is not. Price around PLN 1,250. No. Catalog 0B5398009D. Understanding Audi A6 C7 - S-tronic 0B5 Transmission: Electronic Tapes and Solenoids
  • #4 16306648
    adam_sil
    Help: 14
    Rate: 88
    Ok, thanks mates.
    Regards
