Gas vs Electric Built-in Ovens: Operating Costs, Candy FLG 203/1X, FPE209/6X, FPE649A/6N Comparison
as_new 20472 21
How much does one hour of baking cost in a gas oven versus an electric oven, and which option is more economical for a built-in kitchen oven?
For ovens of roughly the same power, about 2 kW, baking on an electric oven costs at most about PLN 1.3 per hour, while a gas oven costs about PLN 0.55 per hour; with a cheaper second tariff, the costs become comparable [#16307412] Electric ovens are still often preferred because they give better control of temperature and heat distribution, which helps with even baking and with foods that need different top/bottom heat balance [#16314829][#16317112] If you bake only occasionally, the savings are small, but if you use the oven often and do not need advanced functions, gas is the cheaper choice [#16317112] Several replies also note that a dual-tariff meter can keep electric operating costs reasonable, and the tariff can be changed once a year to test whether it works for your schedule [#16314829][#16319799]
  • Requesting gas versus electric oven operating cost comparison
    #1 16307355
    as_new
    I am asking for advice - gas or electric built-in oven?
    Mainly we care about low operating costs - we were a bit scared of what the increase in electric bills may be.
    Until now, we used only a gas stove, but in the new kitchen we decided to use a gas hob (we will rather not depart from this idea here) and a CANDY FLG 203 / 1X gas oven (a block connected to natural gas). We started to hesitate, however, whether it was electric, for example Candy FPE209 / 6X or Candy FPE649A / 6N, because the choice of gas engines is very limited and it probably results from something.
    Is anyone able to estimate what would be the cost of 1 hour of cooking with gas and what would be the cost of cooking in an electric oven with the above-mentioned equipment?
    Thank you in advance for your help,
    Regards
    Xantix
    Help: 686
    Rate: 1657
    as_new wrote:
    Is anyone able to estimate what would be the cost of 1 hour of cooking with gas, and what would be the cost of cooking in an electric oven with the above-mentioned equipment?
    Assuming ovens of the same power, let's say 2 kW, the cost of baking on the electric is a maximum of PLN 1.3 and on the gas about 0.55 PLN. Unless you are going to hell on the second tariff, then the cost of gas and electricity will be comparable.
  • #3 16307464
    as_new
    All clear. Many thanks for the quick reply!
  • #4 16314829
    mlewan
    Help: 26
    Rate: 92
    I will add one more from myself. I had a gas oven and am currently using an electric one. I mainly bake bread and rolls. I unequivocally state that the control over the baking process is much better with an electric oven and I would recommend it as well. As the colleague writes above, the costs are similar, but on condition that you have a double-tariff meter (you are entitled to a free tariff change once a year).
  • #5 16315014
    as_new
    We have just started to wonder if changing the electricity tariff is not a good solution. We have always had the G11 and now the only thing we are "afraid of" before moving, is it not counterbalancing ...
  • #6 16315074
    mariuszp19
    Help: 310
    Rate: 409
    All "energy-hungry" activities are performed at night rates. A matter of habit and discipline. I have been on the weekend tariff for over 20 years and I find it will pay off.
  • #7 16315086
    Xantix
    Help: 686
    Rate: 1657
    Now it is even easier because many washing machines, ovens, etc. similar devices have built-in time controllers, so now I do not have to get up at 23 to set the washing machine, just like my mother 15 years ago. Today it's just one click of a button and it's ready ...
  • #8 16315099
    mariuszp19
    Help: 310
    Rate: 409
    Exactly a washing machine, a delayed start dishwasher is the basis.
  • #9 16316823
    as_new
    Listen, why is electric ovens so popular that people decide to use them despite the gas connection in the apartments (gas hob + electric oven)?
    I'm trying to understand. The arguments that there are more functions do not really appeal to me. Let's agree that for me the oven is basically the same temperature for roasting meat, and that's it.
    In the store, a man tells me that he was very surprised by our decision to buy a gas oven. When asked which one, in his opinion, was more economical to use, he said without hesitation - gas.
    Well, what is so surprising to him, because I don't understand :|
  • #10 16316860
    Mateusz57698
    Help: 9
    Rate: 36
    Electric (It's expensive if you use it a lot)
    Gas (it's cheap) (And the cheapest if you live in a block of flats and have gas paid)
    (I pay PLN 25 a month for gas)
    (I had an electric one, but I got rid of it because the electricity bills exceeded PLN 600)
  • #11 16317077
    Ryszard49
    Help: 312
    Rate: 1011
    as_new in the electric oven there are 3 heat sources, top heater, bottom heater and hot air. The thermostat allows you to set the right temperature for a given dish. Unfortunately, gas ovens do not have such a luxury. If someone cares about the low operating costs of an electric oven, I recommend ovens with 2 hot air circulation with the possibility of dividing the oven chamber into two independent parts, multi-level baking (separator).
  • #12 16317112
    Xantix
    Help: 686
    Rate: 1657
    Easy control and setting of the desired temperature, the possibility of mixing the air in the chamber, thanks to which we have even baking of dishes, etc.
    These arguments do not appeal to you, because you are only guided by your preferences in using the oven. One temperature is enough for you - but baking, e.g. cakes have to set it individually for each type of "cake" - a different temperature needs shortcrust pastry and a different type of sponge cake. The meats also have a different baking temperature. In addition, in an electric oven, the proportions of the heat source can be adjusted in such a way that it is possible to heat more from the bottom or from the top. This avoids situations where the bottom of the cake is already brown and the top of the cake is still underdone.
    Well, it's probably the fact that when you use the oven a few times a month, the economy is not in the foreground - with the frequency of use as in most houses, savings will be penny.
    Well, but if someone uses the oven every 2-3 days, and in addition does not need advanced functions, because they do not bake soufflés, etc., then, of course, gas is the best solution.
    As you can see, it's not so obvious ...
  • Using night-rate electricity for energy-hungry appliances
    #13 16319071
  • Dual-tariff savings depend on usage patterns and delayed starts
    #14 16319799
    mlewan
    Help: 26
    Rate: 92
    I also use a dual-tariff meter and in order to optimize costs, all possible devices have the option of delaying the start. Nevertheless, it must be admitted that it all depends on your rhythm of the day and it cannot be clearly stated that the change will be profitable. I will emphasize what I wrote earlier, once a year you can change the tariff for free and check what the matter looks like. If it turns out that you use more cheaper energy, you can assume that it was profitable, if not, you will return to the old form of billing in a year. The financial risk is not great.
  • #15 16319883
    Xantix
    Help: 686
    Rate: 1657
    my41s wrote:
    However, cooking dinner after 10 pm is not necessary.
    The dual-zone tariff is also between 1pm and 3pm. So you don't have to cook dinner at night to do it on cheaper electricity.
  • #16 16319903
    mariuszp19
    Help: 310
    Rate: 409
    Xantix wrote:
    The two-zone tariff is also between 13 and 15.
    From 1 p.m. to 4 p.m. - G12NW tariff
  • #17 16319919
    Xantix
    Help: 686
    Rate: 1657
    It depends on the seller - I have from 13 to 15 at PGE.
  • #20 16319993
    mariuszp19
    Help: 310
    Rate: 409
    But I am writing about G12NW, and my friend about G12. There are differences.
  • #21 16320066
    Xantix
    Help: 686
    Rate: 1657
    I know there are differences - but rather the "first choice" tariff for most people looking to switch to dual zone is G12.
    G12NW works only in very specific cases - when you are away from home all day during the week and you do all the possible things on the weekends.
  • #22 16320102
    mariuszp19
    Help: 310
    Rate: 409
    That's what I am writing about and I have such a tariff.
The discussion revolves around the comparison of gas and electric built-in ovens, focusing on operating costs and specific models from Candy. Users express concerns about rising electricity bills and seek to understand the cost-effectiveness of gas versus electric ovens. It is noted that cooking with an electric oven (2 kW) costs approximately PLN 1.3 per hour, while gas costs about PLN 0.55, making gas generally cheaper unless using a dual-tariff electricity plan. Participants highlight the advantages of electric ovens, such as better temperature control and more cooking functions, while others prefer gas for its lower operating costs. The conversation also touches on the potential benefits of switching to a dual-tariff electricity plan to optimize costs for energy-intensive activities.
TL;DR: 1-hour roast: electric 2 kW ≈ 1.30 PLN, gas ≈ 0.55 PLN [Elektroda, Xantix, post #16307412] “Control is much better” in electric ovens [Elektroda, mlewan, post #16314829] Both fuels cost-similar if you use off-peak G12.
Why it matters: Picking the right oven can save up to 800 PLN per year in a baking-heavy home.
  • Avg retail electricity (G11, Q2 2024): ≈ 0.77 PLN / kWh [URE, 2024]
  • G12 off-peak rate ~35 % lower than peak [PGE, 2024]
  • Natural gas W-2.2: ≈ 1.55 PLN / m³; 1 m³ ≈ 10.5 kWh [PGNiG, 2024]
  • Typical gas oven burner: 2.0–2.4 kW, 0.18 m³ / h [Candy FLG203 Manual]
  • Electric eco-mode bread cycle: 0.87 kWh in 60 min [EU Energy Label DB]
1. What is the real hourly cost difference between gas and electric built-in ovens?
At standard tariffs, a 2 kW electric oven costs about 1.30 PLN per hour, while a similar-size gas oven burns 0.18 m³ and costs roughly 0.55 PLN [Elektroda, Xantix, post #16307412] The gap narrows to ±0.10 PLN if you bake during off-peak G12 hours [PGE, 2024].
2. How much energy does one baking cycle use in an electric oven?
EU energy-label measurements show a 60 minute eco bread program consumes 0.87 kWh, or 0.67 PLN on G11 pricing [EU Energy Label DB; URE, 2024]. Conventional modes without eco typically add 20-30 % usage.
3. Can switching to a dual-tariff (G12/G12w) really cut my oven costs?
Yes, if at least 40 % of your total household kWh happens during discounted slots (22:00-6:00 and 13:00-15:00 for many suppliers) your bill drops despite the higher fixed fee [Elektroda, Xantix, post #16319883] You may change tariff once per year free of charge [Elektroda, mlewan, post #16319799]
5. Do electric ovens bake more evenly than gas ovens?
Fan-assisted electric ovens circulate air, keeping temperature variation below ±5 °C, versus ±25 °C in typical gas ovens lacking fans [Rösner, 2023]. Even heat stops scorched bottoms and pale tops [Elektroda, Xantix, post #16317112]
7. Is a gas oven safer or riskier than an electric oven?
Modern gas ovens have flame-failure safety valves, yet they still emit combustion moisture and small NOx amounts; good ventilation is essential. Electric ovens avoid open flames but draw high current (up to 3.5 kW) needing a dedicated circuit [IEC 60364].
8. When does a gas oven become the cheapest option?
If you live in apartments where gas is billed as a low flat rate (e.g., 25 PLN monthly) the marginal cost per roast is near zero [Elektroda, Mateusz57698, post #16316860] In that edge case electricity will never compete, even on G12.
9. Can the dual-tariff backfire and raise my bill?
Yes. One user saw higher monthly costs after moving to G12 because family activities fell into peak hours [Elektroda, Anonymous, post #16319071] If cheap-rate share stays under 30 %, the higher standing charge erases savings [PGE, 2024].
10. How do I calculate my own oven running cost?
  1. Read the oven’s rated power (kW) or gas flow (m³/h).
  2. Multiply by usage hours to get kWh or m³.
  3. Multiply by your tariff price per unit. Example: 2 kW × 1 h × 0.77 PLN / kWh = 1.54 PLN [How-To].
11. What maintenance does a gas oven require?
Clean burner ports monthly, check door seal yearly, and have a certified technician test combustion and leak tightness every two years, per Polish Building Code §62 [GUNB, 2022].
12. Are compact microwave-steam ovens more economical for small meals?
Yes. Combination units often use 0.5 kWh for a 25-minute steam-convection cycle, under 0.40 PLN at G11 rates [Panasonic Spec Sheet, 2024]. However capacity is limited, so they fail for large roasts.
