[Solved] LG L2 - the phone does not want to turn on, the logo is hanging
k4rol13 22446 14
How can I fix an LG L2 that only shows the LG logo and never finishes booting?
Try first to enter download mode by holding Vol+ while connecting the USB cable; the phone should display a “DOWNLOAD MODE” message [#16310757] Another reported key sequence is to hold Power + Vol- until the LG logo appears, then release and hold Vol+ and Vol- together [#16310784] If those combinations do not work, check the battery voltage with a meter, because a low battery can block firmware flashing [#16310971][#16311025] The next step is to reflash the firmware (“new soft”) or perform a factory reset / wipe data [#16310971][#16311867] If you are not comfortable doing that, the advice in the thread was to take the phone to a service point [#16311867]
  • #1 16310700
    k4rol13
    Rate: 28
    My mother has LG L2. The phone does not want to turn on, i.e. it turns on as it is at the beginning, only the logo is visible and all the time. In my opinion, the system is down - android. I think I have to upload from the new android. Speak on this topic because I first met this situation and have no idea what to do.
    What is best done in this case?
  • #2 16310757
    KamGr
    Help: 77
    Rate: 203
    Start by checking if the phone enters the download mode
    Press Vol UP and hold it all the time, connect the USB cable to the phone you should receive a DOWNLOAD MODE message.
  • #3 16310784
    tomek4
    Help: 57
    Rate: 100
    1) hold the power button and down (vol -) until the logos lg appears
    2) then release everything and hold down the volume (vol +) and silence (vol -)
    It definitely works my phone has started
    It's on youtube
  • #4 16310802
    k4rol13
    Rate: 28
    It's on youtube
    These activities should I do before the logo appears so at the beginning I have to do it?
  • #6 16310948
    k4rol13
    Rate: 28
    it does not work
    Added after 7 [minutes]:
    tomek4 wrote:
    It does not work, from the very beginning there is the logo of LG, just like on 57 seconds. As I keep quiet and power, the phone reboots and is still the same. As I press vol + and vol - it's a zero reaction
    Maybe there is a different way out?
  • #7 16310971
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    You need to upload a new soft one and check what voltage the battery has beforehand.
  • #8 16311002
    k4rol13
    Rate: 28
    Where to get this soft?
    That's what I write on the battery. Rechargeable Li-lon Battery 3.8V 1ICP5 / 44/62
  • #9 16311025
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    For example, look for a hamtura on hamsters and the battery must be checked with a meter which has a voltage because when it is too small it is the thread from the firmware upload.
  • #10 16311053
    k4rol13
    Rate: 28
    What should be the correct voltage and how could you send a link to download this softa because I am green :)
  • #11 16311058
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    The batteries can be recharged externally only, or you can use charged charged only
    Because charging with a charger can not do anything
  • #12 16311071
    k4rol13
    Rate: 28
    Charges with the charger as I have plugged in it shows that it is charging and when I disconnect it is more
  • #13 16311867
    tomek4
    Help: 57
    Rate: 100
    If you're green, it's the same thing because you're bricking the phone, go to the salon's former point and ask for a vipe data factory reset
    And if you do not win any uncertain roms
  • #14 16311904
    k4rol13
    Rate: 28
    But to upload a new soft pen I can do it :)
  • #15 17197888
    k4rol13
    Rate: 28
    The telephone has been repaired
The LG L2 is experiencing a boot loop issue, where it only displays the LG logo and fails to fully power on. Users suggest attempting to enter download mode by holding the volume up button while connecting the USB cable. Another method involves holding the power and volume down buttons until the LG logo appears, then switching to volume up and volume down. If these methods fail, it is recommended to check the battery voltage and consider re-flashing the firmware. Users also mention the importance of ensuring the battery is adequately charged, as low voltage can hinder the firmware upload process. If the user is inexperienced, seeking professional help for a factory reset or firmware installation is advised.
