LG G FLEX 2 - Includes in the LG logo, and when I attach a charger it is almost
Fu-Fu 3726 4
  • #1 16709901
    Fu-Fu
    Help: 9
    Rate: 110
    Hello!
    LG G FLEX 2, when I turn it on, it turns on to the LG logo and so on and on, while when I attach a charger, it turns on almost completely and turns off.
    Could it be the fault of the battery because I don't know whether to risk it or order a new one.
  • #2 16710830
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    LG is half and half. Either soft or battery. In most cases, battery replacement helped me.
  • #3 17277274
    gezaj
    Rate: 15
    I have the same problem. I replaced the battery and there is only such improvement that the charger works normally but when I disconnect from the power supply it immediately starts restarting again and again. But I don't want to work on the car charger. The phone is 3 months after the warranty (case?) So LG service is out of the question.
  • #4 17283217
    misiekelk
    Help: 47
    Rate: 121
    And heat it up the Prock will rise right away.
  • #5 17284060
    gezaj
    Rate: 15
    And you could write something more :) ?
