Samsung Galaxy J5 Charging Issues: Slow Charge, Disconnection, & Battery Drain Concerns
bornvillain 14550 4
  • #1 16426799
    bornvillain
    Hello, for some time I have a problem with Samsung Galaxy J5.
    The phone does not want to be charged right after connecting, in short:
    - the phone does not charge immediately, I have to move the cable or phone and then catch
    - you can not use or even touch the phone when it connects to charging - because then the charging icon disappears and does not charge and even there is less battery or charge icon, but the phone has as much battery percentage as it had or slightly less (1- 3%)
    - the phone charges slower than it used to be and discharges faster
    - it happens that once it has been successfully connected and charged, after some time it will stop charging itself
    - charging goes more efficiently when the charger is not connected every now and then, only rarely
    It is definitely not the fault of the charger, the phone was checked on 3 Samsung original chargers and a USB cable at the computer.
    There are no visible signs of battery damage or entry to the charger cable. What could it be? Damaged charging socket, battery or maybe something quite different?
  • #2 16426857
    rotombox2
    Rate: 19
    Simply, the repairs are required on the site, or on your own if after the warranty period, the self-charging socket.
  • #3 16426864
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    There is nothing to combine and bend the nests to move (it will break out of the pins and there will be a problem and costs) or it works or not. To exchange
  • #4 16426934
    nutergsm
    Help: 1034
    Rate: 1665
    Usb socket for replacement.
  • #5 16427544
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Undress and check, sometimes you just need to solder again.
