Audi A3 2005 BKD - Brake Lights Ignition Delay and Constant On Issue with KL15 Relay
kubas10 15198 18
Why do the brake lights on an Audi A3 2005 BKD stay on after ignition and only switch off when the KL15 relay is removed?
The fault was a blown 10A fuse in the engine-compartment fuse box that feeds the clutch and accelerator pedal sensors, not the 5A fuse. Replacing/checking that fuse fixed the wrong brake-light behavior [#16314213][#16322366] The brake lamps were being powered through the central electrics/bordnetz module rather than the comfort module, so that area and its fuses were the right place to check [#16321047][#16321485]
  • KL15 relay triggers constant brake lights after ignition delay
    #1 16313721
    kubas10
    Help: 42
    Rate: 1547
    Hello, the ignition of the stop lights is off, the knocks do not press the brake pedal. When the ignition is switched on, they burn constantly. I changed 3 stop sensors, I noticed that after switching on the ignition the lights come on only after about 1.5 seconds (only when the KL15 relay switches on), after removing its lights go out. They do not go out after removing the fuses on the steering wheel. Comfort module released?
  • #2 16313778
    domex32
    Help: 585
    Rate: 2451
    Any mistakes? Perhaps the clutch sensor?
  • #3 16313799
    kubas10
    Help: 42
    Rate: 1547
    There is one error and it concerns the stop light sensor / the spiral from the candles blinks when the ignition is switched on. What does the clutch watch have to do with it?
    domex32
    Help: 585
    Rate: 2451
    They hang on one fuse.
    Have you checked the sensor by the catalog as it should be? As far as I remember, there are 3 types.
    Added after 50 [seconds]:
    And check the rear lamps carefully under the water account and the bulbs fitted in it
  • Brake sensor works correctly with ignition off
    #5 16313891
    kubas10
    Help: 42
    Rate: 1547
    The body is a 3-door hatchback, an additional alloy is also on fire and looking at the diagram, the wires are separated from the rest. Audi A3 2005 BKD - Brake Lights Ignition Delay and Constant On Issue with KL15 Relay
    They only have mass in common, but the pluses are separate.
    Added after 5 [minutes]:
    With the ignition off, the sensor is working properly.
  • #6 16313935
    domex32
    Help: 585
    Rate: 2451
    Is the hook in the car?
  • #7 16313955
    kubas10
    Help: 42
    Rate: 1547
    The hook is gone.
    The stop comes on when voltage after ignition appears, I do not need to turn on the position lights. The rear wiper does not work in the car, I got to it and you can see large amounts of washer fluid that got on the rotor.
  • #8 16314029
    domex32
    Help: 585
    Rate: 2451
    You need to determine whether the bordnetze exposes them or the lamps get electricity, e.g. from the windscreen wiper.
  • #9 16314184
    moto-kord
    Help: 137
    Rate: 505
    Check the wiring in the tailgate I once had such a case.
  • #11 16315673
    kubas10
    Help: 42
    Rate: 1547
    Bieda z nędzą wrote:
    On my nose a 5A fuse was burnt in the box in the engine compartment, and burned by shorting the clutch sensor.
    On Friday I will check and let you know, a very good idea!
    Added after 30 [seconds]:
    Very important note.
  • #12 16320892
    kubas10
    Help: 42
    Rate: 1547
    The fuse from the clutch pedal sensor is all right.
  • #13 16320930
    domex32
    Help: 585
    Rate: 2451
    So where do the lamps get electricity? :)
  • #14 16321047
    kubas10
    Help: 42
    Rate: 1547
    The lights go out when I disconnect in the fuse box:
    F2 5A - Active steering controller;
    F10 5A - MAIN RELAY 5A / Motor controller;
    F12 5A - CENTRAL GATEWAY;
    F28 40A - Relay 2 terminal 15 40A / Fuse box Interior;
    Relay R1 458 - MAIN RELAY / Relay terminal supplied with 30;
    F25 40A - the left brake light goes out - Left indicator / Parking lamp left / FOG LIGHT HEADLAMP left. / BODY CONTROLLER (BODY) / High beam bulb left. / Lion passing light bulb;
    F26 40A - the right stop light goes out and the additional stop - Right indicator / Parking lamp right / FOG LIGHT REFLECTOR on the right / BODY CONTROLLER (BODY) / High beam bulb on the right / Low beam bulb on the right;
    It turns out that from the comfort module, while in the engine parameters I have the following:
    Brake pedal - not depressed (changes to depressed as I depress the brake pedal);
    Brake pedal / TEMPOMAT / - switched on (does not change after pressing the brake);
    Clutch pedal - switched on (does not change after pressing the clutch);
  • #15 16321485
    domex32
    Help: 585
    Rate: 2451
    If anything, not from the comfort module, but from bordnetz (central electrics module). You could look into it, maybe something will catch your eye.
    Check it out yet.
    Can you define the moment when the failure occurred?
  • #16 16321721
    kubas10
    Help: 42
    Rate: 1547
    Check it out yet.
    The one in the trunk on the right?
    The client said it happened suddenly
  • #17 16321753
  • #18 16322366
    kubas10
    Help: 42
    Rate: 1547
    It turned out that the fuse was burned the one that powers the clutch and alloy pedal but not 5A but 10A. Hence this mistake. Thank you all for valuable advice.
  • #19 16323493
    domex32
    Help: 585
    Rate: 2451
    In thanks, we use the "helped" button
The discussion revolves around a 2005 Audi A3 with a persistent brake light issue, where the lights remain on after ignition and only activate after a delay when the KL15 relay is engaged. The user has replaced the stop sensors but continues to experience problems. Various suggestions are made, including checking the clutch sensor, wiring in the tailgate, and the comfort module. It is noted that the brake lights may be receiving power from other sources, and the user eventually discovers a burned fuse related to the clutch and alloy pedal, which resolves the issue. The conversation highlights the importance of checking fuses and wiring connections in diagnosing electrical problems in vehicles.
