Man F2000 98 - ZF Gearbox Gears Jump Out After 30 Minutes of Driving
Adas220 14775 13
Why do the upper gears in a MAN F2000 with a ZF gearbox jump out after about 30 minutes of driving, while the shift lever stays in place, and what should I check?
The most likely cause is worn synchronizer/retarder-wheel parts in the upper gearbox, and the thread’s final fix was to replace the complete synchronizer, the retarder wheel, the ring with the locking stones/pawls, and the oil [#16355630] First, drain the gearbox oil and check for steel or brass filings; if there are no obvious metal particles, refill with fresh oil and test again, but if there is no improvement the box has to be disassembled [#16321175] One reply also points to worn synchronizer teeth as a reason gears can jump out, especially when the lever itself stays in place [#16321390][#16324725] Another suggestion was to check the group-change valve for leaks, but replacing that valve did not solve the problem in this case [#16324526][#16324780] Once the gearbox was opened, the repair required replacing internal synchronizer parts rather than just adjusting the shift jack [#16355630]
  • #1 16316253
    Adas220
    Hello. In the Mana F2000 460HP ZF gearbox, gears jump out on the upper gearbox, but the jack does not change position. To put the gear back in again, you have to knock out and knock the gear in again while hammering, does not always jump. I would add that problems start only after about 30 minutes of driving, how cold it is ok.
  • #2 16320769
    TomasAGC
    Help: 13
    Rate: 210
    Chest to review, do you have a retarder?
  • #3 16321175
    darfur5
    Help: 267
    Rate: 1715
    So for starters - drain the oil from the box and pay attention to what is in it, steel and brass filings. If you find nothing in the oil, pour it fresh and do a test drive, as there will be no improvement, you will need to disassemble the box.
  • #4 16321390
    kaczy2214
    Help: 5
    Rate: 49
    The gear is lost and the shift jack stays in place? If so, you can check the slide's fuse but it would be too simple, it is likely that the teeth on the synchronizer have already worn out and therefore does not hold gears. You can also unscrew the can from high / low and see if the nut from the slide has loosened somehow. But rather everything will end up replacing the synchrones
    • Man F2000 98 - ZF Gearbox Gears Jump Out After 30 Minutes of Driving Drawing_170403.jpg (33.11 KB) You must be logged in to download this attachment.
  • #5 16323739
    Adas220
    This is how the retarder is, and like my friend Kaczy2214 asked the jack, he stays in place.
  • #6 16324526
    Eragon1976
    Rate: 18
    Please check the group change valve for leaks.
    In my opinion, if the synchronizers were worn, there would be a rasp when changing the group.
  • #7 16324725
    kaczy2214
    Help: 5
    Rate: 49
    Worn teeth of the synchronizer cause the gears to jump out, they are milled under the account to clamp the synchronizer under load as they wear out.
  • #8 16324780
    Adas220
    This valve was bought and replaced, but it did not help, so this chest must be disassembled
    Added after 8 [minutes]:
    I still have a question to get to these synchronizers, you have to pull out the whole crate or is this the rear crankcase enough?
  • #9 16324873
    kaczy2214
    Help: 5
    Rate: 49
    It is better to pull the whole box upright on the clutch housing and fix it conveniently and stress-free, repair on the spot is feasible but I do not recommend a waste of time and nerves. I also recommend using a professional, because if someone did not do it, it can get out of this mess
  • #10 16325479
    Cobrat
    Help: 35
    Rate: 502
    You won't do anything without the press, even if you puncture the crate, also as a colleague wrote above give it to someone who does such things. You can remove the crates yourself, they will not delete you for assembly and disassembly ;)
  • #11 16327294
    Adas220
    The press is there, but from what I remember it is necessary to know which mode they should come off from the roller, and if I remember correctly I used to undress such a chest so much that without a retarder I will answer around Friday-Saturday as I take it and describe what it is the problem was. Regards
  • #12 16327303
    Cobrat
    Help: 35
    Rate: 502
    You associate well ;) , with the retarder the difference is that you unscrew a few more screws and remove it. Act in that case.
    PS. However, if you were to take up an unequal fight, I would like to post a slap. On page 25 you can see clearly what goes down which way from the roller. (just not a fraction of 04.300 ;) )
    Schemat ZF...16s181.pdf (2.76 MB)You must be logged in to download this attachment.
  • #13 16331084
    kaczy2214
    Help: 5
    Rate: 49
    One more small note, when disassembling the shift ring, be careful not to splash stones and springs because you will be looking all day for where it fell and also replace them because it also holds the slide in place
    It is here
    • Man F2000 98 - ZF Gearbox Gears Jump Out After 30 Minutes of Driving Drawing_170208.jpg (30.4 KB) You must be logged in to download this attachment.
  • #14 16355630
    Adas220
    Hello, the problem is solved and I replaced the retarder wheel, the whole complete synchronizer, this ring on the synchronizer with stones that this paw moves and new oil. I bought Euroricambi parts. It describes how I see because I do not do it on a daily basis so I do not know professional names.
The discussion revolves around a problem with a Man F2000 truck equipped with a ZF gearbox, where gears jump out after approximately 30 minutes of driving. Initial suggestions include checking for a retarder and inspecting the gearbox oil for metal filings, which could indicate wear. Users recommend examining the synchronizer teeth for wear, as this could prevent proper gear engagement. If the synchronizers are worn, disassembly of the gearbox is necessary to replace them. The conversation also touches on the importance of using a press for disassembly and the need for careful handling of components during repairs. Ultimately, the issue was resolved by replacing the retarder wheel, the complete synchronizer, and using new oil, with parts sourced from Euroricambi.
