Audi 3.0 TDI V6 - High fuel consumption, Injector corrections
audiobeats 14757 9
Why does my Audi 3.0 TDI show higher real fuel consumption and a rising oil level even though there are no fault codes and the injector correction values look normal?
The thread’s answer is that the injector data in groups 072–077 are not normal and point to bad injectors, while groups 013 and 014 were considered OK [#16321297][#16321376][#16343989] The helper also said that if those 072-group values still look like that after about 1500 km, the injection system is “rubbish” and the DPF is probably bad too [#16321376] Frequent DPF regenerations at about 150 km/h on cruise control were specifically mentioned as something to check [#16321297] In short, the likely cause is not just a minor correction issue; the injectors should be treated as faulty and the DPF/regeneration behavior should be checked as well [#16343989][#16321297]
  • #1 16321118
    audiobeats
    I have a problem with my Audi 3.0 TDI 233HP ASB.
    Well, the combustion on the computer came out to me about 7.5 l / 100 km, and the tank came out about 10 l / 100 km, I also noticed an increase in oil in the engine.
    The car doesn't kick, no problems with starting
    I will add that the car is still mounted DPF and apparently functional but I'm not 100% sure, it starts quite often when I drive the highway and keep the cruise control at about 150 km / h.
    I did the diagnostics and you can't see any errors, there is only one value that puzzles me quite well, so the engine in the 020 group in second place has a value of -40.5C Celsius
    As for the value of injectors, they are as follows after about 400 km of driving:
    Group
    013 -0.19; 0.19; -0.42
    014 0.19; 0.33; -0.09
    072 -6.0; 0.0; -4.0
    073 -2.0; 0.0; 0.0
    074 0.0; 6.0; 6.0
    075 0.0; 0.0; 0.0
    076 2.0; 4.0; 0.0
    077 0.0; 6.0; 2.0
    Could there be a fault other than the injectors?
    I have heard the opinion that certainly injection, but after all the corrections do not look bad, there is no smoking.
    I am asking for some advice, I am not using the car yet because I am afraid of the engine.
  • #2 16321297
  • #3 16321346
    audiobeats
    They were added some 1500km ago.
    The information about the DPF afterburning lights up on the display
    And what to look for when checking DPF?
    Thanks for the link will definitely help ;)
  • #4 16321376
  • #5 16321716
    audiobeats
    Oh, all of them? What should these groups look like?
    Added after 14 [hours] 46 [minutes]:
    It's probably only number 75 working?
  • #6 16343784
    audiobeats
    So nobody can help?
  • #8 16344392
    audiobeats
    Oh, or all on the table.
    Was there any experience with regeneration?
    I'm afraid a little to whom to give because some sell with new coding numbers others think that you do not need new codes, and how is it in reality?
  • #9 16344442
  • #10 16345511
    audiobeats
    Now You scared me because I read some reviews about remanufactured and apparently it was flying.
    Please tell me with good injections what should long-term corrections after 1000 km look like or something?
The discussion revolves around an Audi 3.0 TDI V6 (233HP ASB) experiencing high fuel consumption (10 l/100 km) compared to the expected 7.5 l/100 km, alongside an increase in engine oil levels. The user reports no starting issues or performance problems, but is concerned about injector corrections and the functionality of the DPF (Diesel Particulate Filter). Diagnostic results show no errors, but injector values indicate potential issues, particularly in group 072. Responses suggest that the injectors may be faulty and that the DPF could also be malfunctioning. The user seeks advice on checking the DPF and the implications of injector regeneration, expressing concerns about the reliability of remanufactured injectors.
