Interpreting Groups 72-77 Results for A6 C6 3.0TDI Injector Dose Correction
Marelli 18147 4
  • #1 16315518
    Marelli
    Rate: 55
    A6 C6 3.0 TDI
    At idle speed, as soon as the hoof is put on white after the gasification, the problem disappears after a while on the free again the same.
    Injections are: 044 511 50 37.
    The oil does not come. How to interpret results from groups 72-77 ??
    Could this be the fault of the injector ??
  • #2 16315642
  • #3 16315678
    Marelli
    Rate: 55
    And what exactly do these delays mean in blocks 1,2 and 3 of the group, eg 74 ?? Ie. Calibr. Pressure 1, 2 and 3 ?? Or what values are responsible for efficient injection and what kind of used?
  • #5 16317072
    Marelli
    Rate: 55
    Ok, thank you for the comprehensive answer. greetings
