LED Driver 50W Repair - COB Flashing: Diagnosing OB3330 Issue, Swapping Components & Measurements
bohunmike 7011 5
  • #1 16322419
    bohunmike
    Rate: 32
    I have a problem as in the subject. Checked diodes, substituted electrolytes, swap mosfet, swap MKT and of course the COB itself. After connecting it flashes with a frequency of approx. Once every 1s. No load, 42.2 V under load, measuring 26 V diode contacts. I measured resistances and capacitors in smd, no short circuits, resistances are normal. The driver itself is OB3330. Is it possible that it is damaged?
    As the electrolyte capacity at the output increases, the flashing frequency decreases, but that's no wonder. Where to find the reason
    Power supply photo:
  • #2 16322549
    aaanteka
    Help: 729
    Rate: 1193
    How did you load the inverter itself?
    Check carefully, long-term operation of COB on another power supply on nominal parameters. Only in this way can you be sure of its condition.
    helpful topic
  • #3 16322558
    bohunmike
    Rate: 32
    I charged COB. Six different ...
  • #4 16323137
    W.P.
    Computer PSUs specialist
    Help: 773
    Rate: 1235
    bohunmike wrote:
    LEDs checked,
    Did you also check the one at R19?
    What about the voltage at the electrolytic capacitor at the controller? I am asking for an average value (it flies in time with the diode flashing).
    Please, remove the other side of the CD.
  • #5 16327616
    bohunmike
    Rate: 32
    So my mistake and my lack of self-confidence :) Driver OK, six COBs down. Subject to close.
  • #6 16327781
    aaanteka
    Help: 729
    Rate: 1193
    The most common fault, so it's always worth substituting a resistive load with parameters corresponding to the nominal LED parameters.
