RALF LED - LED floodlight - flashes / lights up and goes out at 1s intervals
lotiss 7569 4
  • #1 16307937
    lotiss
    Rate: 11
    a year ago I bought a BOWI LED floodlight from Gdańsk - 30 W
    version with motion sensor (without light sensor), I attach a photo because the manufacturer (presumably Chinese, cardboard without description) provides this floodlight for many distributors and sells it under various brands .....
    floodlight designed for outdoor installation - I mounted on the building wall, a solid aluminum housing, unfortunately no instructions,
    problem: from yesterday it lights up and goes out at 1s intervals
    I conclude - the led is functional, so the "module" or motion sensor fell ...
    do you have experience or is there a chance to fix such a floodlight or just a trash can ?????
  • #2 16307995
    p407s
    Chance is always just need to know each other, do you have any guarantee on it? If so, then let the manufacturer swap in, if not, I suggest opening it and uploading a photo of the electronics, otherwise it's hard to advise.
  • #3 16309057
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1322
    Electronics (power supply) is a regular current driver (available even on Allegro) and also probably sold under various brands. Unless the sensor "fell" but doubtful ...
  • #4 16309630
    lotiss
    Rate: 11
    previously the light was "shaking" - one day she was shivering, the next day not.
    so it seems that electronics have gone down ...
    Wednesday / Thursday I will get a ladder and disassemble the lamp, send pictures of the guts
  • #5 16324973
    lotiss
    Rate: 11
    attached picture ....
    it turns out that the lamp has a 2-year warranty (I give it to the service), all elements i.e. driver, sensor, led are available for purchase in Polish online stores
    we will see what happened ....
    • RALF LED - LED floodlight - flashes / lights up and goes out at 1s intervals WP_20170304_14_40_49_Pro.jpg (357.85 KB) You must be logged in to download this attachment.
    • RALF LED - LED floodlight - flashes / lights up and goes out at 1s intervals lampa 1 - driver.jpg (408.2 KB) You must be logged in to download this attachment.
