Unreachable Configuration Address Issue: Connecting Nanostation M2 to Huawei B525 Router
muzik21 7692 6
  • #1 16322926
    muzik21
    I have a problem with the NanostationM2 configuration. The device wants to connect to the Huawei router so that Nanostation sends a Wi-Fi signal to neighboring buildings located on my plot. The problem appeared at the very beginning - namely, I can not enter the address for the NanostationM2 configuration. I know that Nanostation is to be connected through the power supply to the router, but if I understand correctly, to be able to configure Nanosation, must I first connect the LAN cable to my laptop? Each attempt to enter the configuration address ended with the message "this site is unreachable, the server needed too much time to respond". Previously, I changed the IP address in the properties of the network card. I will be grateful for your help.
    RM
  • #2 16324334
    jimasek
    Help: 3783
    Rate: 2682
    Reset to factory settings did you do? The default address should be 192.168.1.20 ubnt / ubnt
  • #3 16324529
    muzik21
    I did, several times, I can never open the default address - each time a message is thrown that the server needed too much time to respond, possibly that the page could not be opened, a change in the network was detected. Only twice I managed to enter the configuration page, after trying to save the settings, the page did not open
  • #4 16324549
    jimasek
    Help: 3783
    Rate: 2682
    And what about the addressing on the network card? Are you permanently set?
  • #5 16325149
    muzik21
    Well, yes, the addressing is fixed.
  • #6 16325169
    jimasek
    Help: 3783
    Rate: 2682
    I mean what?
  • #7 16325595
    muzik21
    192.168.1.10, I also tried with a different number at the end, because from what I read the last digit must be different from 20, because 192.168.1.20 is the address of the antenna.
    Added after 15 [hours] 57 [minutes]:
    I managed to solve the problem with entering the configuration address. However, now I can not quite configure Nanostation. I set the access point as a bridge in mode. I choose the SSID of the network with which the antenna will connect and enter the password. After connecting the Nanostation to the router, it does not send a signal. Where is the mistake?
The discussion revolves around configuring a Nanostation M2 to connect with a Huawei B525 router. The user initially faced issues accessing the configuration address (192.168.1.20) for the Nanostation M2, receiving a "server needed too much time to respond" error. Despite multiple factory resets and attempts to change the network card's IP address, the user struggled to access the configuration page. Eventually, the user managed to enter the configuration but encountered difficulties in setting up the device as a bridge to connect to the router's SSID and password, resulting in no Wi-Fi signal being transmitted. The conversation highlights troubleshooting steps and configuration challenges faced during the setup process.
