Huawei b525s-23a router from T-mobile and connection of another LAN provider
zone21 11949 9
Can I configure a Huawei B525s-23a router from T-Mobile to work with fiber/LAN internet, or do I need a new router?
You can only use it for wired internet if the firmware lets you switch a LAN port to WAN, but the T-Mobile B525s-23a is usually a stripped-down version where that WAN-over-cable function is disabled, so if the option is missing the router will not work as an Ethernet WAN device [#17905673] One reply says the WAN setting is normally under LAN4 in Huawei’s admin panel [#17903524], but the poster could not find any editable WAN/LAN4 tab. If your router does not expose that setting, you need another router for the fiber/LAN connection [#17905673]
  • #1 17900256
    zone21
    I looked through the forum but unfortunately I did not find a similar topic. I would like to add that I am green in these matters, therefore some questions may seem pointless.
    I have a Huawei B525s-23a router from T-mobile. I had a prepaid internet connection in this router. Unfortunately, the limit started to piss me off, so I decided to opt for LAN fiber. Today they connected this internet to me, but unfortunately when I plug the cable into the Huawei router, nothing happens. Is it possible to somehow configure it with the LAN internet? Do I need to buy a new router unfortunately?
    Thanks in advance for all answers.
  • #2 17903455
    zone21
    Nobody will help? Need to buy a new router?
  • #3 17903524
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Administration panel in the router and set the WAN port.
    The WAN is under the LAN4 port (if I remember correctly).
  • #4 17904106
    zone21
    Would you be so kind and write where exactly is the tab with these WAN and LAN4 settings?
    Thank you in advance
  • #5 17905633
    zone21
    I looked through all the tabs in the control panel and the words "wan" and "lan" appear only in the "device information" tab, as below. However, you can't edit anything there. Huawei b525s-23a router from T-mobile and connection of another LAN provider
    matek451
    Help: 4352
    Rate: 5808
    This is the pain-castrated B525 from T-mobile. The Germans deprived it of RJ11 and USB (they are blinded) and the WAN function on the cable. Normally in Huawei it is possible to set the WAN port as Ethernet and this tab should be in FW. If it doesn't, you won't use it for wired internet.
  • #7 17905766
    zone21
    In that case, thank you for the specific answer :)
    Regards and the topic to be closed.
  • #8 17917985
    _POCk_ee
    Help: 8
    And it is impossible to upload a new software? ethernet !. And the router was to be used only to separate the internet from the cable; /
  • #10 17931350
    _POCk_ee
    Help: 8
    And another important question, the aa male-male usb cable has D + and D- crossed lines?
    are they going straight?
    Thank you
The discussion revolves around the Huawei B525s-23a router provided by T-Mobile and the user's attempt to connect it to a new LAN fiber internet service. The user is struggling to configure the router to accept the LAN connection, as the router appears to lack the necessary WAN settings. Responses indicate that the B525s-23a model has limitations imposed by T-Mobile, including the absence of WAN functionality for Ethernet connections. A suggestion was made to check the administration panel for WAN settings, but it was confirmed that the router's firmware does not support this feature. The user expressed gratitude for the clarification and indicated the topic could be closed.
