Help Needed: Setting Up Huawei B525 Router with Orange Internet, Connecting to Both WiFi Networks
Qki77 19512 8
  • #1 16684623
    Qki77
    I have a Huawei b525 router and internet from orange,
    my brother on the laptop searches from this router two wifi, one is HUAWEI-B525-B342 and the other HUAWEI-B525-5G-B342,
    I am searching for only one of the first wifi and the internet on it is 2/3 times weaker, if there is any possibility of setting to find this network with me.
  • #2 16684695
    mk64
    Help: 6
    Rate: 27
    If you do not have a network card that supports 5 GHz, you will not do anything.
  • #3 16684791
    matek451
    Help: 4352
    Rate: 5808
    I confirm, the B525 transmits wifi in two 2.4GHz and 5GHz bands and in the AC standard. It's best to have an AC card. My brother uses the 5GHz lenght, only 2.4GHz in the N standard, and we do not know what connection is being set up. you'll get the best speed by connecting your computer with a LAN cable to the B525, especially when the network card has a 1Gbit / s LAN port.
  • #4 16685138
    Qki77
    my network card is ASUS PCE-N10 11n Wireless LAN PCI-E Card and supports only 2.4Ghz,
    and when I connect the router to the computer with a cable it pops up to me that it uses the Killer e2200 Gigabit Ethernet Controller, but the internet speed does not change is still the same as using wifi.
    I am currently using a constantly ethernet cable, maybe there are different types of this cable? Does it depend on him?
    Could this be somehow changed in the settings? Or buy a different network card?
  • #5 16689254
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @ Qki77
    Since your network works only at 2.4 GHz, there are probably more networks in this band there.
    Make a wifi scan InSSID v2 / Home and insert the measurement result here.
  • #6 16689288
    Qki77
    @ KOCUREK1970 I've ordered a card that works on 5Ghz frequency, and I'll do a scan tomorrow after 4pm because now I have no way.
  • #7 16689314
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Qki77 wrote:
    I have ordered a card that works on 5Ghz frequency
    What exactly?
  • TP-Link Archer T4UH adapter and WiFi chart shared
    #8 16690229
    Qki77
    @ KOCUREK1970 exactly this "TP-Link Archer T4UH (1200Mb / sa / b / g / n / ac) DualBand"
    I do not know myself, I do not know whether good or bad, I read a few opinions, I wanted to use usb to not tire, I hope I did not make such a terrible choice. In case of anything I can always send back.
    here is a chart from this program that you gave me, I do not know if I downloaded this very good program because there were several versions and if this is what you wanted to see.
  • #9 16690359
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Qki77 wrote:
    Internet speed does not change, it is still the same as using wifi.
    You have to remember that it is the GSM internet and the meaning of the network range itself, the load of the transmitter, the distance to it, etc. is of great importance here.
    Qki77 wrote:
    here is a chart
    The wifi network coverage is not sensational.
The discussion revolves around setting up a Huawei B525 router with Orange internet and the challenges faced in connecting to two WiFi networks: HUAWEI-B525-B342 and HUAWEI-B525-5G-B342. The user experiences weaker internet speeds on the 2.4GHz network due to their network card (ASUS PCE-N10) only supporting 2.4GHz. Recommendations include upgrading to a dual-band network card (TP-Link Archer T4UH) to utilize the 5GHz band for better performance. Users also suggest performing a WiFi scan to assess network congestion and interference on the 2.4GHz band. The importance of Ethernet connections for optimal speed is highlighted, although the user reports no speed improvement when using a LAN cable.
