JBL Flip 3 Portable Speaker: Mini USB Input Not Working - Alternative Charging Methods?
WisniaxD 9174 7
  • Charging through the audio jack is not possible; replace the Mini-USB port
    #1 16324139
    WisniaxD
    Hi, I have JBL flip 3, and yesterday when I wanted to charge it, the mini usb port didn't work
    I have working chargers because I tried several and nothing.
    My question is whether I can somehow replace the port itself or whether I can charge it through the other port (I do not know exactly what it is, but I think the mini jack input) is used to connect to the computer but I do not know if the speaker is loading
    kokapetyl
    Help: 1787
    Rate: 2101
    All you have to do is repair (replace) the USB socket.
  • #3 16324175
    WisniaxD
    Can I name it myself? take it apart and I can only solder it on myself
  • #4 16324183
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    If you have a soldering station, flux and experience in soldering such elements, yes, but since you ask such questions, you can not handle it yourself.
  • #5 16324188
    kokapetyl
    Help: 1787
    Rate: 2101
    WisniaxD wrote:
    only if it can be soldered on its own
    As the name says "mini USB" so also solder pads are mini. It only depends on your abilities and your equipment.
  • #6 16324192
    WisniaxD
    So where would it be best to give it to someone with some skills to do this to me?
  • #7 16324194
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Eg GSM service.
  • #8 16324201
    Adam-T
    Help: 834
    Rate: 1096
    WisniaxD wrote:
    (I don't know exactly what it is, but I think the entrance to the mini jack)
    And God forbid you, connect any charger there.
The JBL Flip 3 portable speaker is experiencing issues with its mini USB charging port, which is not functioning despite using multiple working chargers. Users suggest that the port can be repaired or replaced, but caution that this requires soldering skills and appropriate tools. If the owner lacks experience, it is recommended to seek professional help, such as a GSM service, for the repair. Alternative charging methods through the mini jack input are not viable for charging the speaker.
