JBL Charge 3 Not Charging: Speaker Turns On/Off, Only One LED Lit, Intact Socket - Need Help
Mysitique 22326 1
  • #1 17718585
    Mysitique
    My problem is as follows:
    I connected my JBL Charge 3 to charging after a few days of not using it, the speaker does not respond to charging, plugging it into charging, the discharged speaker turns on for a few seconds and then turns off. Only one LED is lit, indicating the speaker charge. I would like to add that the speaker did not suffer any fall or other complications and the charging socket is intact. Thank you for your help.
  • #2 17718699
    E8600
    Help: 529
    Rate: 2515
    Here you have a similar case.
