Opel Insignia 2.0 CDTI EcoFlex SportsTourer Estate: Unresponsive Trunk Button & Potential Fixes
remiksl 39033 5
  • Tailgate button failure after frost and water ingress
    #1 16324259
    remiksl
    Rate: 14
    Opel Insignia 2.0 CDTI EcoFlex SportsTourer Estate,
    I have a problem with the tailgate, and it does not react to the button anymore. Until recently, after long holding the finger on the button after a while, the boot opened, now it does not react at all. After the frost, water gathered there. I felt it under my finger, I made a small hole in the protective rubber to go down but do not fix the problem. I open the boot from the inside out. Is the whole lock replacement or electronics failures?
  • #2 16324374
    tkaczu1
    Help: 22
    Rate: 92
    Hello. Install the whole lock and clear should help. I did this in my vectra. The lock is not hermetic and dirt accumulates in it which causes no contact.
  • #3 16324376
    domex32
    Help: 585
    Rate: 2451
    This microstick in the castle, most likely, may already be for exchange. Either way, without undressing, you can not judge it.
  • #4 16324877
    remiksl
    Rate: 14
    And how to go about it? I never undressed the zipper. Any advice?
  • #5 16324899
    tkaczu1
    Help: 22
    Rate: 92
    You have to remove the upholstery from the flap and the access is simple to remove the entire cassette with the lock.
    link
  • #6 16325699
    remiksl
    Rate: 14
    Ok, I will take days to do it and let me know how it went.
