[Solved] Opel Insignia 2.0CDTI Power Issues: Turbo Reload, Low Recharge and P0402 EGR Error
Cars20 33342 8
  • EGR fault and blocked DPF causing limp mode
    #1 17099253
    Cars20
    Rate: 11
    Hello. Problems began a month ago when the car on the 3rd gear at 3.5 thousand revolutions began to reload the turbine, the computer showed too low recharging (valve damaged) after the race turned out that however nothing helped so I put new wires from underpressure and then nothing ... Turbo was able to check and in very good condition variable geometry etc. However, a few days ago I turned off the car after re-launch, the mound kick did not want to enter the turn and go. I connected the computer and P0402 it was probably an EGR error I temporarily blinded the badge and suddenly started to walk normally but without a turbo ... (which time goes normally ...). After this situation I went for a better computer and checked the DPF. He was blown out with very high pressure and nothing more. Maybe someone knows what's happening with this car?
  • #2 17099439
    kaczor4011
    Help: 10
    Rate: 60
    Does the engine have a quenching hood? (I do not know too much about the blades) I had very similar symptoms in the 1.4 tdi polo and had a damaged extinguishing flap - it was closed.
  • #3 17099528
    szymitsu21
    Help: 343
    Rate: 1300
    Read it again and think about it.
  • #4 17099530
    Bartol tech
    Rate: 40
    Check the pipe from the left side of the battery often
  • #5 17099937
    Raywood
    Help: 5
    Rate: 16
    Once I had this case in insignia 2.0 160km.
    The turbine control valve was guilty. He cut himself.
  • #6 17100568
    Cars20
    Rate: 11
    The whole valve pipe is new ...
    Can it behave like that from the flaps in the collector?
  • #7 17101096
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    Inlet tight system ??? , EGR closes ???? , turbo vacuum valve known, DPF blown ??? And what about soot burning? (what is the difference of pressures at standstill and at 4,000 rpm), the timing phase (on the interlocks) to the spr .... so to the beginning ...
  • #8 17303726
    Cars20
    Rate: 11
    The problem was that some magician had erased the map that he did not see, so DPF told me so
  • #9 17303756
    Cars20
    Rate: 11
    Added after 18 [minutes]:
    Problem with DPF
The discussion revolves around power issues in an Opel Insignia 2.0CDTI, specifically related to turbo reloading, low recharge, and a P0402 EGR error. The user reports symptoms including turbo malfunction at high RPMs, low recharge indications, and a temporary resolution by blocking the EGR valve, which led to normal operation without turbo assistance. Responses suggest checking various components such as the turbine control valve, inlet tightness, EGR functionality, and DPF condition. A follow-up indicates that a previous map erasure may have contributed to the DPF issues.
