Seeking Knowledge on Inspection Deletion in Opel Insignia - Greetings from Marek
dr.Psuja 89131 12
How do I reset or delete the inspection reminder in an Opel Insignia?
In the Opel Insignia, reset the service/inspection reminder through the MENU button: turn on the ignition, press MENU, select Vehicle Information, open Oil-Life System, then press and hold RESET while also holding the brake pedal until the service display jumps and the service interval overview is cleared [#10555420] [#10620532] The older method with the meter reset button and the "INSP" / "---" display is reported to work on other Opels like Vectra, Astra, and Zafira, but not on the Insignia [#10544999] [#10546751]
  • #1 10544605
    dr.Psuja
    Rate: 19
    Deleting inspection in Opel Insignia , does anyone have such knowledge , please help
    greetings Marek
    Moderated By Pawel wawa:
    3.1.13. (10.9, 15) It is forbidden to publish posts that violate the rules of Polish language spelling, careless and incomprehensible. Warning.
  • #2 10544999
    peloks
    Help: 97
    Rate: 225
    Erasing the inspection is done as follows:
    1. Turn off the ignition
    2. Press and hold the meter reset button and turn on the ignition
    3. The display shows the indication "INSP"
    4. Hold the meter reset button until the display shows the indication
    5. Release the meter reset button
    6. Turn off the ignition.
  • #3 10545486
    kajaba autoserwis
    Level 30  
    Help: 118
    Rate: 667
    peloks wrote:
    Inspection deletion is done as follows:
    As this is not for the Vectr(s)?
  • #4 10545539
    peloks
    Help: 97
    Rate: 225
    Vectra, Zafira, Astra........ Unless Opel has changed something in the latest models.
  • #5 10545565
    pipałosia
    Help: 74
    Rate: 179
    1. turn off ? or however turn on and point 6. also turn off probably a small mistake.
  • #6 10545591
    peloks
    Help: 97
    Rate: 225
    pipałosia wrote:
    1. Turn off ? or however turn on and point 6. also turn off probably a small mistake.
    This is not a mistake. When you insert the key, the ignition is supposed to be off. only I forgot to add in point 2 about turning on the ignition (already corrected).
  • #7 10545648
    kajaba autoserwis
    Level 30  
    Help: 118
    Rate: 667
    I don't know if ''Insignia'' will accept it.
  • #8 10546751
    dr.Psuja
    Rate: 19
    Insygnie does not accept it
  • #9 10555420
    pioart
    Help: 343
    Rate: 1473
    Turn on the ignition.
    Press the "MENU" button.
    Select the Vehicle Information menu. (2)
    Call the "Oil - Life System" menu item.
    Press the reset button. Hold down the reset button , press the brake pedal and hold down.
    The service display jumps.The service period overview has been cleared.
    Seeking Knowledge on Inspection Deletion in Opel Insignia - Greetings from Marek .
  • #10 10620532
    dr.Psuja
    Rate: 19
    Press the MENU button
    The service display jumps.The service period review has been cleared.
    Clearing the inspection in the Opel Insignia
  • #11 10620864
    pioart
    Help: 343
    Rate: 1473
    dr.Psuja wrote:
    Turn on the ignition.Press the MENU button ……. .
    After all, I wrote it. It has to work.
  • #12 12593314
    Adam1113
    Hello, when I press the menu I can't select the vehicle(2) information, I can only select 1 or 3 thank you in advance
  • #13 15090093
    lukasz_szczecin
    Adam1113, select the MENU button so that it appears: RESET and oil % LED, then press the SET/CLR button and hold it until you hear a signal - that is, resetting the oil consumption level.
The discussion centers around the process of deleting the inspection warning in the Opel Insignia. Several users provide step-by-step instructions, which include turning off the ignition, pressing and holding the meter reset button while turning on the ignition, and following specific prompts on the display. There is some debate about whether these instructions apply to the Insignia, with users noting that similar methods may work for other Opel models like the Vectra, Zafira, and Astra. Additional methods for resetting the oil life system are also shared, emphasizing the need to navigate through the vehicle's menu system. Some users express difficulties in accessing the correct menu options.
