Ducato 2.2 2008: Uneven Performance, Autocom P0094 Error, Fuel Pressure & Dose Variations
wecia91 9942 6
  • #1 16325264
    wecia91
    Rate: 227
    Hello, ducato 2.2 2008, it works unevenly, the read errors autocom P0094, the parameter, the readings go crazy, the measured fuel pressure 114-400, the set fuel pressure 230-500, the fuel dose 0.0-24, the set fuel dose 0.0-33. The car can also normalize itself sometimes, but when I add gas or turn it off and start it, it goes crazy and after two minutes it goes out, when the readings are evenly read, the measured fuel pressure is 220, the set fuel pressure is 230, the fuel dose is set to 5.5. can cause this condition, maybe someone has processed such a failure.
  • #2 16328060
    KarizmoGSM
    Help: 95
    Rate: 291
    You have a leak somewhere, stick your head and you will find out, no one will buy a glass.
    It should be 300 bar at idle, or the regulator on the pump sits down
    KariMax Paweł Kalkowski
    Kronikarska 8, Łódź, 92-624 | Company Website: www.cfiat.pl
  • #3 16328438
    wecia91
    Rate: 227
    a head and even a webcam were put under the mask with zero leakage
  • #5 16435765
    Piiotrekb5
    Hello. And I have such a problem with Ducato 2.2 puma. After the engine overhaul, when I start it, it works perfectly for 10-15 seconds, and then it starts to go crazy, throws it as if he did not go to all the pots. Faults in the sensor on the injection rail. This sensor was replaced with a new one (it did not help) I replaced the pressure regulator with the pump too. What may be, there is no connection, can the wiring harness checked, the wires from the sensors are ringed ok. The plugs are covered with contact. The injectors also tested PPPA before the renovation, regenerated. I have no idea. Maybe someone had a similar problem. The only thing that is interesting is when I pulled the plug from the regulator on the pump during uneven work, it starts to work normally
  • #7 16435799
    Piiotrekb5
    I thought so too, but I mentioned it and it's the same, that's why I write on the forum, and in the post I wrote that it was mentioned and nothing
✨ The discussion revolves around a 2008 Ducato 2.2 experiencing uneven performance, indicated by error code P0094 and fluctuating fuel pressure and dosing readings. Users suggest potential causes such as fuel leaks, faulty pressure regulators, and issues with the injection rail sensor. One user notes that after an engine overhaul, the vehicle runs well initially but then exhibits erratic behavior, leading to further investigation of the wiring and injectors. The conversation highlights the importance of checking for leaks and the functionality of the fuel pressure regulator, as well as the possibility of wiring issues affecting sensor performance.
