Fiat Ducato 2008 2.2JTD 100KM 195,000km - Black Smoke, Power Loss, Increased Consumption, EGR Error
stefangolf 14370 9
How can I diagnose black smoke, power loss and increased fuel consumption in a Fiat Ducato 2008 2.2 JTD with an EGR fault?
Black smoke, loss of power and higher fuel use in this Ducato point first to too little air for the amount of fuel, so check the air filter, intake, turbo and EGR before blaming the injectors [#16334551] Try blanking the EGR as a test to see whether the symptoms change [#16334614] Because this is a common-rail JTD, the injectors are not checked "on the table" as a simple bench test; instead, do a return/overflow test [#16334501] In that test, the less fuel an injector returns, the better, and you compare the values between injectors [#16334585] If the intake is tight and the return test is OK, then the injectors are less likely to be the cause [#16334551][#16334585]
  • #1 16334342
    stefangolf
    Hello, I have had a problem with Fiat Ducato 2008 for two days. 2.2JTD 100KM mileage 195 000km (100% sure, the car from new at home). Two days ago, he started gently kicking under load, especially from 1800rpm up to about 2500. The next day, smoking soared and power dropped, average combustion increased by about 1.5l, I barely came home. There is no more strength to go in 4th and 5th gears. Whether cold or warm, the same cloud of smoke lacks power. after connecting the computer the only error from EGR, but it has been checked, there are no other errors. I bet that the injection is pouring, maybe tomorrow I will be able to pull them out and check on the table. There is a lot of info on the net that pistons flew together with the injections, how to check it without removing the cap ?? measure the pressure??
  • #2 16334401
    citromaniak
    Help: 53
    Rate: 394
    Make injections and see how it will go, the pressure should be around 30bar on each piston
  • #3 16334501
    darfur5
    Help: 267
    Rate: 1715
    JTD injection will definitely not check on the table because it is a common rail fuel system. Take a transfer test.
  • #4 16334524
    stefangolf
    When I write "on the table", I mean to deliver them to a specialist in fuel systems.
  • #5 16334551
    darfur5
    Help: 267
    Rate: 1715
    AAA yeah! sorry i didn't think. Before you remove the injection, check the air filter and the turbo. Black smoke from the pipe indicates that there is not enough air in relation to the fuel, so start from the intake and finally leave the injections.
  • #6 16334564
    stefangolf
    I have already checked the intake. Everything tight. Apparently there was some mistake from the swim but he deleted and does not return. I will check this filter again. In this test for overflow, the less fuel from a given injector, the worse? Do you understand this well?
  • #7 16334585
    darfur5
    Help: 267
    Rate: 1715
    The fewer the better . I don't know what expense the injections have in your car, so you need to search the net or your friends will suggest patience!
  • #8 16334614
    jenusz11
    Help: 33
    Rate: 196
    check the flow if it is not cheating, if the values are ok try to blind the egr to the test
  • #9 16335101
    stefangolf
    Today there will be an EGR plug, I will put it in and check. but from the very beginning it seems to me that the injection, smoking is huge. so it seems to me too much fuel (or poor atomization) in relation to the amount of air. No leak in the inlet. I will also check the readings from the transfer and later transfers. On the computer, the doses were practically identical only for 2 cycles. there was a bit more. But all the posts are green.
  • Similar Ford case involved turbo, EGR, and injector failures
    #10 16337179
    kakibara
    Help: 202
    Rate: 1284
    My case, the same engine only in the Ford, the turbo pipe burst, the cloud is barely coming, - you write no leakage at your place - okay
    EGR twice, - He can barely drive.
    100 thousand km - the first injection burned a hole - ignited but the engine was getting wetter than oil from the front - weaker and weaker. kicked in black.
    160 thousand second set of injections plus change of program - before the exchange you can feel clearly for a few thousand km that weak - nothing kicks.
    now 212 thousand and the exchange two-pounding shit like hell and shakes the car, I like the most comfort and cruise control from the hill accelerates the hill barely goes - ha ha
    Greetings.
The discussion revolves around a 2008 Fiat Ducato 2.2JTD experiencing black smoke emissions, power loss, and increased fuel consumption after 195,000 km. The owner reports a noticeable power drop under load, particularly between 1800 to 2500 rpm, and an EGR error code. Responses suggest checking the fuel injectors, as the common rail system complicates direct testing. Recommendations include performing a transfer test on the injectors, inspecting the air filter and turbo for blockages, and potentially blocking the EGR for diagnostic purposes. The owner confirms no intake leaks and plans to check injector performance and EGR functionality further.
