Wiring Connection for Razer Kraken's Green, Red, Blue, Copper Wires to Jack: Diagram Needed
jarek.jackowiak 10155 2
  • #1 16326413
    jarek.jackowiak
    Hello, I have a Razer Kraken, they have 4 wires: green, red, blue and copper - how to connect to the jack? Could anyone draw a diagram for me, even in paint? :>
  • #2 16327173
    tarkan1
    Help: 16
    Rate: 17
    You would post a picture where you missed it, it will be easier for you to help what to what. Do you have a meter? You will have to check which wires go to the headphones, microphone.
    Do not count on the finished product, because no one here will tell what the manufacturer meant when putting these headphones together.
  • #3 16327330
    Kinggred
    Just like his colleague "tarkan1" said, it would be useful to take a photo and even the simplest meter. If it did not break off at the jack itself, the matter is quite simple, you just have to solder wires of the same color to each other. They are insulated with this colorful 'varnish' so to be able to solder them you have to burn it, Wiring Connection for Razer Kraken's Green, Red, Blue, Copper Wires to Jack: Diagram Needed Wiring Connection for Razer Kraken's Green, Red, Blue, Copper Wires to Jack: Diagram Needed
    And then scrape off the burnt paint. Remember that the more carefully you do it, the better the sound you will have. Also remember that after scratching (if you burn the entire exposed part) all the wires will be colored copper (which is poor in my photos), after soldering, you must insulate them. The easiest way to do this is with heat shrink insulation.
    If, on the other hand, you do not have sufficiently long wires from the jack, you can as a last resort (I do not recommend) remove the rubber from it (remember to put the heat-shrinkable insulation before soldering) (better not to pull the metal part because the sea breaks, it is better to cut it or "shoot") . Then you know what and where you solder.
