Razer Kraken USB to 3.5mm Jack Adapter: Compatible with Smartphone/MP3 & Gembird Audio Adapter
PolskiWariat 8715 8
  • #1 16721269
    PolskiWariat
    Rate: 18
    Hello, I do not know if the question is in a good section, please move in case of problems. I stumble on various topics related to it all the time, but I can't find a uniform and consistent answer. Can I play with a 3.5mm jack to listen to music, e.g. from a smartphone or mp3? from e.g. using: Gembird Jack Stereo 3.5mm audio adapter can someone explain it to me and write or explain how it can be done or bought? thank you greetings
  • #2 16721411
    procsa
    Help: 173
    Rate: 364
    You won't connect with this adapter, you can try to connect via usb otg sooner but I doubt the phone will detect the headphones. The headphones work via USB and are installed as a separate audio player, and the 3.5mm jack output is an analog output.
  • USB OTG adapter suggested for phone detection
    #3 16759688
    PolskiWariat
    Rate: 18
    ok, I don't close the topic, I will write it, but I don't know when: /
    procsa wrote:
    sooner try to connect via usb otg but I doubt that the phone will detect the headphones. The headphones work via USB and are installed as a separate audio player, and the 3.5mm jack output is an analog output.
    can you give me a link to the store . Or maybe this one? : http://allegro.pl/ap6-kabel-przejsciowka-jack-3-5mm-aux-usb-host-otg-i6621570337.html
  • USB OTG is the required adapter
    #4 16759957
    procsa
    Help: 173
    Rate: 364
    No, it's ordinary USB OTG
    Because from what I understand, you want to connect headphones with a USB plug to your smartphone?
    Here someone is testing such a solution, first the adapter you wanted to buy is shown, but it does not work.
    Here also, usb otg works, so there is a chance, although these are only movies on YT so it can be different.
  • #5 16761686
    PolskiWariat
    Rate: 18
    So exactly I mean just something weird that such a cell powers the backlight :O . But I will buy a fortune and it may not be useful in the future :D
  • #6 16762023
    procsa
    Help: 173
    Rate: 364
    It probably depends on the phone, but the standard is as in USB 2.0 max 500mA with USB OTG.
    Remember that the phone must support OTG otherwise nothing will happen. The easiest way to check this is to plug in a FAT32 flash drive.
  • #7 16765285
    PolskiWariat
    Rate: 18
    In the sense that usb otg pendriva? Yes
    procsa
    Help: 173
    Rate: 364
    Check if the phone supports OTG 100%, connect a pendrive to the phone via this OTG adapter. Of course, it is first necessary to check in the phone's specifications whether it supports.
  • #9 16765316
    PolskiWariat
    Rate: 18
    In the reviews they write that I support it should work thanks when I buy it I will write
The discussion revolves around the compatibility of the Razer Kraken USB headphones with a 3.5mm jack adapter for use with smartphones and MP3 players. Users express uncertainty about whether the Gembird Jack Stereo 3.5mm audio adapter can facilitate this connection. It is clarified that the Razer Kraken headphones operate via USB and are recognized as a separate audio device, making direct connection through a 3.5mm jack unfeasible. Suggestions include using a USB OTG adapter, but compatibility depends on the smartphone's support for OTG functionality. Users are advised to check their phone specifications and test with a USB OTG device, such as a FAT32 flash drive, to confirm support.
