Headphones with microphone - replacement of the 3.5mm jack (5 wires)
Abuk007 33615 9
How do I identify the correct wire connections when replacing the 3.5 mm TRRS jack on my headset with microphone?
You should identify the wires with a multimeter first, because the color code on this headset is not reliable and at least three wires are definitely for the headphones [#15708552][#15708822] One user mapped the wires as blue = left earphone, red = right earphone, copper = headphone ground, green = microphone, and green-red = microphone ground, but the original poster later found that the manufacturer’s colors were unusual, so verification by measurement is safer [#15708539][#15708795] For the headphone side, expect about 25–65 Ω on the speaker wires; the microphone will not measure like a speaker, and an electret mic often shows a couple of kΩ on the plug [#15709789][#16700931] Solder the wire ends and the jack contacts first, then join them carefully to avoid melting the plastic shell [#15708525]
  • #1 15708506
    Abuk007
    Hi
    I have a problem with replacing the 3.5mm jack on my headphones (HyperX Cloud 2).
    These are headphones for a 4-pole jack (with a microphone). The old one broke and unfortunately I did not note how the colors of the wires are attached to it.
    It looks like this:
    Five cables (what I deduce in parentheses)
    green (right earpiece)
    blue (left earphone)
    green-red (weight from the headphones)
    copper (microphone?)
    red (mass from the microphone?)
    I tried to solder it according to this scheme:
    As grounding, selecting the variant from this diagram:
    While the sound in the headphones itself worked worse with the microphone - there is noise and it is enough to touch the headband, there are immediately some strange feedback. I wrote to the manufacturer but their support does not want to help by covering the warranty terms.
    Not to mention that soldering such tiny wires is a huge pain in the ass :P I have already burned 2 plugs with a soldering iron (plastic has fused between the joints).
    I am asking for advice on the correct connection and soldering.
  • #2 15708525
    piotrek22101
    Help: 695
    Rate: 1421
    The weight of the microphone is on the copper, together with the weight of the headphones, we put it on the housing 4. As for soldering, whiten / solder the ends of the wires and plugs, then solder gently.
    • Headphones with microphone - replacement of the 3.5mm jack (5 wires) 44BFDBFE-C632-4978-B671-C5326C3F0C92.png (23.02 KB) You must be logged in to download this attachment.
  • #3 15708539
    alien90fr
    Help: 100
    Rate: 107
    Blue - left earphone
    Red - right earphone
    Copper - the weight of the headphones
    Green - microphone
    Green - red - ground of the microphone
    I guess that's how it should be
  • #4 15708552
    dedito
    Help: 527
    Rate: 595
    The microphone should be detachable, so it should be possible to measure what belongs to the microphone on the jack.
  • #5 15708795
    Abuk007
    Green - microphone
    red and copper are together in one shirt
    blue, green, and red-green in the other
    I checked blue and green and they are from the headphones, and the two-color one is from the ground (when I connected, the sound worked well).
    The strange colors of the manufacturer.
    dedito wrote:
    The microphone should be detachable, so it should be possible to measure what belongs to the microphone on the socket.
    That's right, it is plugged into one of the headphones.
    This could explain these surges, but when I tried in the reverse order (i.e. copper + red-green to ground instead of red + red-green), the microphone did not work at all.
  • #6 15708822
    piotrek22101
    Help: 695
    Rate: 1421
    Meter and measure the resistance. Three are headphones for sure.
  • #7 15709776
    Abuk007
    What values should I expect on the cables?
    If I hook the microphone, will the resistance increase on the mass from the microphone?
  • #8 15709789
    piotrek22101
    Help: 695
    Rate: 1421
    The ones I had were from 25? to 65?, as for the microphone, it had nothing.
  • #9 16225810
    trebacz181
    Hello, I have the same problem, I took them to some GSM service. I The sounds work, everything and the microphone, what should I do? Because I looked through the topic but did not deduce anything from it :( Please help
  • #10 16700931
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    What is the resistance of the microphone? Measure on the plug. Electrets with an amplifier (very widespread) have a couple of kilohms (I checked some meter set to 20k, correct side 1k75, reverse 1k33; for 2k out of range correct, reverse 1k30; another copy for 20k 1k45 and 1k15, 2k out of range range and 1k1); dynamic (a small chance for it to be like that) a few hundred discussions, the same in both directions. If they are not connected, the resistance on the plug will be "infinite", if they shorted it, the resistance will be "zero".
The discussion revolves around the replacement of a broken 3.5mm jack on HyperX Cloud 2 headphones, which feature a 4-pole configuration for audio and microphone functionality. The user is uncertain about the wiring colors after disassembly, identifying five wires: green (right earpiece), blue (left earpiece), green-red (weight from headphones), copper (microphone), and red (mass from microphone). Various responses suggest potential wiring configurations and emphasize the importance of measuring resistance to diagnose issues. Users recommend soldering techniques and checking the microphone's resistance, which should typically range from a few hundred ohms to a couple of kilohms for electret microphones. The conversation highlights troubleshooting steps and the challenges faced when dealing with non-standard wiring colors from the manufacturer.
