LG 28LB450B: PCMCIA Slot Compatibility with CI Card, Conax System, and NC+ Viewing
zwn51 9156 6
  • #1 16326988
    zwn51
    Rate: 14
    This TV has a socket described as PCMCIA. Please enter if this is the same as the CI card slot? And does this socket work in the CONAX system?
    I am asking because you can't enter chat in LG, I waited over 20 minutes on the phone - with no results. There is nothing on the subject in the manual.
    I want to use this TV to watch pre-paid nc + but I don't want an additional box connected to the TV.
    Zbigniew
  • #2 16327052
    intenso
    Help: 480
    Rate: 617
    And how do you want to connect a satellite antenna to this TV?
  • #3 16327721
  • #4 16329436
    zwn51
    Rate: 14
    To intenso:
    After all, I wrote that I will use nc + television which has the option either through a decoder or through the CI CI CAM MODULE. And I prefer the CI module because I will avoid an additional box. I already had such a module and the TV was connected via a coaxial cable from the supplier's network. I understand that the concentrator would be connected to the satellite dish.
    Please correct me if I am wrong.
    To mihal2002:
    It is true that I do not have instructions but what I saw on the internet is absolutely not that the CI socket supports the CONAX system.
    Hence my question and your answer does not explain this issue
    WITH
  • #5 16329554
    intenso
    Help: 480
    Rate: 617
    You won't connect a satellite dish to this tv.
    The tv must have a DVB-S2 tuner.
    The fact that a given provider encodes Channels in Conax or Nagra like Cyfrowy Polsat is not of the slightest importance for tv, because the decoding is done by the card with the module, tv only has to be compatible with such a module and that's it.
  • #6 16332187
  • #7 16333899
    zwn51
    Rate: 14
    I'm closing the topic
The discussion revolves around the LG 28LB450B TV's PCMCIA slot, questioning its compatibility with CI cards, specifically for use with the CONAX system and NC+ viewing. Users clarify that the TV lacks a DVB-S2 tuner, which is necessary for direct satellite dish connection. The CI slot is confirmed to support CI CAM modules, allowing for the use of a prepaid NC+ service without an additional decoder box. However, there is uncertainty regarding the specific support for the CONAX system, as the manual does not provide clear information on this compatibility.
