NC+ Hotbird 13.0E Configuration: CAM CI+ Module, Antenna, 100% Signal Strength & 11 TV Programs
jerry74 9204 2
  • #1 16624395
    jerry74
    Help: 21
    Rate: 58
    Yesterday I bought an NC + set (plate + CAM Cl + module)
    I installed the antenna using the SatFinder application. I connected to the TV and inserted a CAM Cl + card.
    In the satellite settings, the signal strength and signal quality indicators are 100%.
    HOTBIRD 13.0E satellite
    After scanning, I found only 11 TV programs, all paid, no Polish-language and 13 radio stations. All not Polish-language.
    I asked in NC + they said that I have to wait for the activation of the 24h card.
    I am afraid that this is a "standby" answer, so I ask here should I not look for FTA programs from Hotbird and the card has little to do with it?
    mariuszp19
    Help: 310
    Rate: 409
    And you didn't sometimes set the antenna to ASTRA? Common mistake. Rotate the antenna slightly to the west and look for the signal.
  • #3 16624412
    jerry74
    Help: 21
    Rate: 58
    I'll check, I'll let you know. Thanks for the quick reply.
    Added after 54 [minutes]:
    You were right, more than 1,000 channels jumped.
    Thanks again.
