[Solved] Skoda Superb sedan - Could not open "big" twind tailgate
sp3rat 12954 3
  • #1 17244462
    sp3rat
    Rate: 11
    For some time there have been problems with opening the "large" tailgate. I can only open a small part of the hatch.
    My car is Superb 2 2008, 2.0 TDI 140KM, sedan with double tailgate, twindoor.
    I checked the cables under the hatch trim. They were worn but not torn off. I checked the switch (right to open the large hatch). It turned out that it has a resistor soldered inside (with an unknown value and I damaged the resistor). When I bypass the resistor, a small trunk lid opens (you can open it with two handles), when I increase the value of the resistor above 120 Ohm to approx. 800 Ohm, nothing happens.
    Does any of your colleagues know what the value of the resistor in the switch / right handle for opening the large hatch should be? No. of this switch (handles) 3T0 827 566C
    Where can I look for the fault?
    I did not check the cables at the transition from the trunk to the body. I don't know if I will find a plug there or something that will help me check the cables.
    Please give me some advice.
    Jurek
    sk700
    Help: 173
    Rate: 420
    In VAGs, the "parameter" is usually 180. You can try or in this case as well.
  • #3 17244577
    sp3rat
    Rate: 11
    Thank you very much.
    When trying to measure this resistor, I had several readings with a value of 180 Ohm.
    I think the switch is ok. I will solder a new resistor.
    But the problem will not solve it, because I have already replaced such a resistor with "short".
    Jurek
  • #4 17270578
    sp3rat
    Rate: 11
    Summary.
    I won't write much, but still ...
    For me, in my case, the failure was in the lower beam of the trunk, right next to the hatch.
    I unscrewed the sheets and plastics of the lower beam.
    I moved the plugs, moved the actuator itself (up - down, but rather up, as suggested by one forum member from another trip).
    In a word, I have not seen a fault, but it has been fixed.
    As suggested by my colleague sk700, I repaired the upper flap switch by inserting a 180 ohm resistor. The switch works. But the failure of this switch had no effect on my problem (I broke the switch while searching for a failure).
    I hope someone will find this description useful :)
    Jurek
