Renault Megane II Cabrio 2.0T 2005: Rear Window Operation Issues & Folding Roof Troubleshooting
kubas10 16203 4
  • #1 16479810
    kubas10
    Help: 42
    Rate: 1547
    Hello, Renault Megane II 2.0T 120kW 2005 The front windows work fine while the rear windows do not work. Only pressing the button on the handbrake lever opens and closes all windows. The front ones are controlled by mass and with the help of a cable I am able to raise and lower them, when it comes to the rear ones, I can only raise them (after giving + 12V they go straight up without interruption) but they do not lower. The folding roof does not work, there are 3 plugs in the window switch on the driver's door:
    blue 6 wires - front windows;
    white 6 wires - rear windows;
    white thin 3 wires - glass blockade - I checked and works;
    In all plugs there is + 12V after switching on the ignition, weight and then 2 wires per windscreen raise / lower.
    Moderated By CameR:
    What exactly is your question?
    Reg. 3.1.15. Do not ask immediately in the forum, if you have not checked anything yourself or have not attempted self-diagnosis. Remember that advice is given remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and brief description of the fault.
  • #3 16480952
    kubas10
    Help: 42
    Rate: 1547
    Swap switch (besides I controlled it with a cable), a gray plug under the R2 driver's seat in the water but after doing everything right the problem remained. There is a transition from the driver switch to the rear engine plug. The front and rear windows work only when the main switch is pressed on the handbrake!
    Added after 2 [hours] 19 [minutes]:
    Can an inoperative roof cause the rear windows not to work?
    Added after 6 [hours] 40 [minutes]:
    In the diagram below I have marked "x" brown wire which I do not have in the UCH which blocks rear windows. The question is, after blocking the windows with a button in the driver's panel, should they work with the switch from the driver? The lock works properly because after turning it on, + 12V appears on the rear switches, but should it not go to the UCH?
  • #4 16483499
    kubas10
    Help: 42
    Rate: 1547
    The right windshield has stopped working today: /
  • #5 16529961
    kubas10
    Help: 42
    Rate: 1547
    The modules in the door fell.
