Citroen C4 2007 1.6 HDI - ABS No Communication, Vehicle Speed Error, ABS Pump & Cube Diagram
rwuhp 18813 17
How do I diagnose a Citroën C4 2007 1.6 HDi with no communication with the ABS module, vehicle speed errors in all modules, and no power at the ABS connector, and what is the ABS pump pinout?
For this C4 ABS no-communication fault, the main checks are the BSM power supply and the ABS feed relay, not just the pump itself. The Bosch ABS without ESP uses pin 30 on pins 2 and 3, pin 15 on 18, pin 31 on 1 and 4, and CAN on 26 and 15 [#16333167] A VIN is needed because there are several ABS versions fitted to this car [#16334060] The large double relay bolted to the BSM under the hood feeds the ABS, so the BSM fuses and relay output must be checked [#16352915][#16352887] In the end, the fault was a damaged BSM: the fuse was good, but voltage did not reach the relay [#16487204]
  • #1 16330302
    rwuhp
    Rate: 128
    Hello, how about the Citroen C4 2007 1.6 hdi no communication with abs without esp all calculators have a vehicle speed error, I changed the abs pump but it is unchanged and that is why I need an abs cube diagram or diagram powered in advance thank you for your answer
  • #2 16333128
    rwuhp
    Rate: 128
    I see that no one will work with the pattern
    mako110
    Help: 37
    Rate: 264
    30-2,3
    15-18
    31-1,4
    can-26.15
    without esp, so says TD
  • #4 16333868
    rwuhp
    Rate: 128
    Thanks buddy for the response to my request on Saturday I will look what and how I will answer the results of my research thanks
  • #5 16333922
    ALIBABA I
    Help: 223
    Rate: 537
    Witai col. Georges knows a lot about it, maybe he will speak, and do not mess with each other because you will only spoil it, wait for Georg to write you.
  • #6 16334060
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Only for him you need VIN. Because there were several versions of the equipment. And after VIN he will choose everything as it should.
    ABS Can be from BVoscha, TRW, VDO Siemens.
  • #7 16340498
    rwuhp
    Rate: 128
    Hello, this schematic does not match pin 2i3 is free in the plug there are no cables. This is Citroen C4 2007 vin VF7LC9HXC74582544 ABS is BOSCH
  • #8 16340728
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Tug cables, up to 30cm behind the plug. You should find rot.
  • #9 16352858
    rwuhp
    Rate: 128
    The cables are ok, there is no voltage, no direct voltage or after ignition in the abs plug and the fuses are all OK, unless they are hidden
  • #10 16352887
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    DC voltage and fuses for bsm OK?
    Recently, I saw a car where the power and mass were new and those in the beam were cut off.
  • #11 16352915
    domex32
    Help: 585
    Rate: 2451
    A large double relay bolted to the box where there is a bsm under the hood, feeds ABS.
  • #12 16352973
    rwuhp
    Rate: 128
    Yes fuses for bsm and next to bsm in a small box also ok, tomorrow I will check the relay that colleague domex32 mentioned
  • #13 16353049
    Pfemek
    Help: 83
    Rate: 342
    This relay is sometimes not added during some corrective action? Originally, it is rather not ... I ask out of curiosity. I've always associated it with burnt 307'dems ... ;)
  • #14 16353245
    domex32
    Help: 585
    Rate: 2451
    It's under factory bundle, so probably not :)
  • #15 16373154
    rwuhp
    Rate: 128
    So the cables are not rotting, the relay is different, I guess I will have to cut the installation and walk on the cables in the plug there are two thick masses and one thick cable in which it should definitely go, plus, if the beginning of the cable must also be the end. I want to believe that no one has a pattern after all, this is not a space vehicle but a citroen
  • #16 16373495
    ALIBABA I
    Help: 223
    Rate: 537
    why 307 were burning, yak
    Because I have it too
  • #17 16376382
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    As far as I know, 307 burned for two reasons.
    ABS installation, and did not turn off the electric power assist motor.
    Those that were to burn were burned, and they are repaired. Unless the batsman put his hands on, they will continue to burn.
  • #18 16487204
    rwuhp
    Rate: 128
    sorry that it is only now replying to a damaged bsm the fuse was good but the voltage did not go out on the aforementioned relay
The discussion revolves around a 2007 Citroen C4 1.6 HDI experiencing ABS communication issues, specifically a vehicle speed error despite changing the ABS pump. Users suggest checking the wiring and voltage at the ABS plug, as well as inspecting the BSM (Battery Supply Module) and associated relays. The importance of the vehicle's VIN for accurate diagnostics is highlighted, as different equipment versions may exist. A schematic diagram for the ABS system is requested, but discrepancies in pin configurations are noted. The conversation also touches on common issues with the ABS installation in related models, such as the Citroen 307.
