Peugeot 307 2.0 HDi: ABS, ESP Indicators On, Unresolved After ABS & Brake Pump Replacement
ferg48 6984 6
  • #1 16776450
    ferg48
    Hello, not long ago I bought a Peugeot, in which the ABS, ESP indicators and a blinking stop popped out. The lights came on one week after purchase. After connecting to the computer, it showed an error - the recirculation pump, the mechanic decided to replace the ABS and brake pump, but it did not do anything. Now I have an unrepaired car, two parts I don't need, and the mechanic said that you don't touch the car anymore.
    Help please.
  • #2 16776554
    Doktorr
    Help: 287
    Rate: 1098
    You have to take the car to a mechanic who knows what he is doing.
  • #3 16776584
    stanisławpiotr
    Help: 211
    Rate: 832
    It will be difficult to help you if you do not have diagnostic equipment. We need to know what the problem is currently in order to give you an answer.
  • #4 16776612
    ferg48
    I have already visited two mechanics, both of them said that the ABS pump ... I will try to connect it to the computer again to see what exactly is the error.
  • #5 16776671
    cobraa
    Help: 84
    Rate: 290
    Take a picture of the screen with errors or prints will give you
  • #6 16777217
    Doktorr
    Help: 287
    Rate: 1098
    Always check the power and weights under load before deciding to replace an ABS assembly.
  • #7 16777239
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Check fuses. You have one burnt, if not the abs, power harness.
The discussion revolves around a Peugeot 307 2.0 HDi experiencing persistent ABS and ESP indicator lights after the replacement of the ABS and brake pump. The owner reports that the warning lights activated shortly after purchasing the vehicle, and diagnostic checks indicated an issue with the recirculation pump. Despite replacing the ABS and brake pump, the problem remains unresolved, leading to frustration with the mechanics involved. Suggestions from forum members include seeking a knowledgeable mechanic, using diagnostic equipment to identify current errors, checking fuses, and ensuring proper power and weight checks before replacing components.
